Question about Microsoft Xbox 360 Console
RROD comes on but it doesnt even attempt ti boot up
I turn on my xbox 360 then does nothing at all and then the RROD comes on, but nothing is running at all? does this mean that my motherboard is fried. I have takin apart the xbox and then i have fixed the x brackets twice by replacing them with rubber washers and screws, and it worked for about a month. So, i repaired it again and it worked again. But now it won't even boot up but it says i have the RROD.
  • aarons890 Jan 06, 2009
    Ya, the fans are on. I thought about resoldering it but i have never done a solder job before. i have the solder and the solder gun but do you know if there is a video or not teaching that for an xbox?
    would doing a Bga reflow work because i could do that
    Sergeant:
    Champion:
  • 378 Answers
Do the fans turn on? The screws may just be shorting against the motherboard or it needs to have the GPU resoldered.
Posted on Jan 06, 2009
  • VIDEOGAME REPAIR SERVICE
    No dont try it. It is somthing that can only be done with expensive machines which hoook up to computer for alignment. You can view some videos if you want on youtube. Search for BGA replacement videos.
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
What do i have to do to fix error code E73
The Sticks Method:
Apr 24, 2010 | Microsoft Xbox Console
My xbox 360 wont conect to my tv and if it does it goes fizzy
this is the correct way to fix an xbox - do not attempt the hot towel trick - a simple x clamp replacement may solve the problem temporarily - but this is the only reliable long term solution (if this doesn't work - the chip will need reballing.
Apr 08, 2010 | Microsoft Xbox 360 Console
My xbox keeps saying e73 can you help
The Sticks Method:
Apr 02, 2010 | Microsoft Xbox Console
E73 xbox
The Sticks Method:
Apr 02, 2010 | Microsoft Xbox 360 Console
How do i fix my xbox 360 e73??
The Sticks Method:
Feb 05, 2010 | Microsoft Xbox 360 Controller
Hi... i have three lights flashing? can you help please
itz rrod......
or may b due to power failure,
chck unplugging all plugs frm ur 360 n reconnecting it, if it works then its nt a rrod, if it doesnt ...
then itz rrod, u need to send your xbox 360 to fix it..
or need to get it xclamped:
here is the whole process to do a permanent fix *xlcamP* of rrod on ur xbox 360:
http://www.megaupload.com/?d=2LEW79G4
Dec 27, 2009 | Microsoft Xbox 360 Console
After RRoD fix, hangs at splash screen and no front lights
ya appliyng thermal past does little if
nothing for the problem your discribing.
did you heat up the G.P.U. and keep
the C.P.U.cool wth the fan till you got
two reds? if that the case there may
be more diconects under the G.P.U
It is fixable but you need specail equipent
that will compress both sides of
the chip as you heat it to around
320c that will fix problem boards like
yours 90% of the time
Rob
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox freezein
Thisi s probably a precursor to the RRoD. Basically had the same thing happen to me a few weeks ago. Call MSFT (800 4myxbox) and tell them you have the rrod and you'll get it fixed for free.
Dec 15, 2008 | Microsoft Xbox 360 Console
RROD xbox 360 help fix plz, no other sites plz
Contact MS support they fix it for free. Or goto www.llama.com if that don't work then google ti.
Dec 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
