Question about Denon SC-M201 Main / Stereo Speaker
Speaker has no bass
Hey my speaker has no bass coming from it at all.the other speaker is perfect.what could be the problem?the broken speaker has a little bit of sound not much tho.everythin is connected up.thanks ali
  • 33 Answers
Make sure there are no wires that could be crossed (i.e. positive and negative).  Also check the speaker for any tears below the cone in above the magnet.  Hope this helps.  Good luck.
Posted on Jan 06, 2009
I had my speakers 3/4 volume and they were fine. later they just started making a quiet crackling and the bass seems to not be in the sound, so it sounds tinny.
If you feel happy to do it I would take out a driver and try to look at the capacitors on the crossover for any leakage and if you have a multimeter handy check that the ohm's on the bass driver to see if they are within the stated range,a continuity test or a 9v battery across the bass terminals should tell if coil is broken,also is this just on the one speaker or both?
Oct 04, 2016 | JBL Audio Players & Recorders
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
Hey i would like to know the rms power handling on these L8 L750
It is 150 watts. for any more info on this speaker, copy this website: http://www.doublefishdesigns.com/forum/rcf/L8L750.PDF
Jan 14, 2010 | Rcf L8L750-16ohm 8-Inch Mid-Bass 16 Ohm...
I have logitech speakers for my computer. I need a new cable that goes from the bottom of the bass speaker to the two smaller speakers. A couple of the pins are broken on the plug that plugs into the bass...
logitech rarely has replacement parts. and for this model is not for the u.s. distribution so youcan not even call u.s tech support for help. try ebay or craiglist. if the connector is not proprietary you might be able to get a electronic repair shop to repin the connector.
Jul 24, 2009 | Logitech Audio Players & Recorders
Adcom GFA 5500 right channel emits horrible sound. Broken highs and no bass. Is is repairable by a semi amatuer?
Adcom makes a great amplifer! Usually broken highs and no bass means blown speaker. Try hooking it up to a completely different input source. Try different speakers also. If problem persists, check the fuse. Most will have a fuse on the back you can screw out. Some have two fuses (one for each channel) If this doesn't fix the problem it could be expensive to fix. Also, does this model ave the thermal protection light and if so, does it come on at all?
Jun 22, 2009 | Adcom GFA-5500 2-Channel Amplifier
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Logitech Z-5500 satellite speaker stand broken
i do not know if logitech sell replacement stands but
http://www.crutchfield.com
and
http://www.best buy.com
both sell good speaker stands. you may be able to find one on there.
Feb 25, 2009 | Logitech Z-5500 Computer Speakers
6x9s cone not working!
can you swap speakers with other one?if so do this and if speaker still sounds bad it is definately the speaker. there is really no way to take speaker apart and repair
Oct 02, 2008 | Infinity Reference 6412cf Coaxial Car...
1999 Toyota RAV4
Hey Robert. It could be one of a few things. I had trouble with my speakers too.
If you still have the factory head unit in your car, the static may be because the speakers are damaged.
If you have a new or non factory head unit in it and you have the factory speakers in the car, the speakers will have a static sound when turned up because they have trouble supporting the amount of watts and power that are being supplied to them.
Another problem I think of when you say static is the metal and plastic or your car "rattling" against each other when bass shakes the area around your speaker. If that's the case, you just nee to put something in there that surpresses the amount of vibration that comes off your speaker and flows into the speaker mount.
Hope this helped.
Jun 12, 2008 | 1999 Toyota RAV4
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Denon SC-M201 Main / Stereo Speaker Logo
348 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
