Question about JVC RX-318 Receiver
JVC RX-318 keeps blowing fuses
I replaced a blown fuse and everytime I replace the fuse and turn the unit back on, the fuse blows instantly.
What is wrong??
  • 120 Answers
Could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Posted on Jan 06, 2009
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
My JVC RX-801V has a short? The 5 amp fuze burns out every time I replace it. what could be the problem?
Probably the output transistors have blown or the amplifier capacitors are dried out.
Fuses are there to protect you and the device from further damage. Repeatedly replacing a fuse without fixing the cause of why it keeps blowing in the first place isn't a wise decision.
Sep 10, 2014 | Audio Players & Recorders
BLOWING FUSES INSIDE UNIT. REPLACE FUSE. BLOWS INSTANTLY
hello because theres a dead short and the fuse is doing it's job could be number of thing that are wrong. 1 shorted diodes/ 2 shorted output transistor/ 3 shorted resistors /4 blown or swelled capacitors get an engineer to check it out good luck
regards
shaun
Dec 27, 2010 | JVC TH-A10 System
JVC RX 505v stereo receiver keeps blowing fuses. Replaced fuse with specified rating (125v 5 Amp) but still keeps blowing fuse. Fuse appears black inside and I see a flash when I apply power. Can...
The likely cause of this is a dead short in the power supply. I don't receal the specifics of this unit, but there should be a set of four(4) diodes or a single bridge rectifier in the main power supply area. Check this/these for a direct short using a diode checker. Other than that, the output transistors being shorted can cause hte same symptom. Without seeing the actual unit, I can not tell for sure. If you know how, check the output transistors as well. Report your results here.
Dan
Nov 30, 2010 | Audio Players & Recorders
Tv blowing fuses
More likely to be either shorted out bridge rectifier or MOSFET in the primary circuits of the power supply. You need to Ohm out those parts.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sylvania+LC320SS8+
Dec 22, 2009 | Sylvania LC320SS8 32 in. LCD Television
Turn it on and blows fuse replace fuse and plug it in and it blow
You need to have the receiver serviced. The fuse is blowing because some part in the power supply or amplifier section has failed. A service technician will need to troubleshoot the unit to determine what parts need to be replaced.
Jul 10, 2009 | JVC TH-C50 System
Reverse lights fuse blew
hi
check the wire because if the fuse keep blowing there's a wire somewhere on the car that has contact with the frame so everytime you put your car on reverse the 12V wire shortcut on the frame so the fuse blow check all your positive wire and your bulb as well
Good luck
Jun 19, 2009 | 1997 Ford Explorer AWD
Keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Jun 14, 2009 | Teac AG-V8600
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
ECM BATT fuse keeps blowing
That fuse provides power for the fuel pump. Either your fuel pump is blowing the fuse or there is a shorted wire.
Nov 22, 2008 | 1995 GMC Jimmy
JVC RX-318 Receiver Logo
651 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
