Question about ASUS Eee PC 900 Notebook
My asus Eee pc 900 screen goes blank on boot up.
Everything light up -the wi-fi,HD,power etc.Have check on the net and found no answer.Help!
I lost wi-fi drivers (Win XP) in eeepc 900
Hi there!If you go to this site here:http://support.asus.com/Download.aspx?SLanguage=en&m=Eee+PC+900%2fXP&p=20&s=1You can download them.Select WinXP from the drop down list, then scroll down and click the plus next to Wireless.Download the driver in there, and install it.Cheers,Alex
May 31, 2011 | ASUS Eee PC 900 Notebook
When i start my asus eee pc 900 laptop i get an error it says
BIOS / system is not able to read ur boot files and boot sector on HD...press F8 when system starts and get into Safe Mode or Last known good comand that worked etc etc...and then do a system scan
Jan 11, 2010 | ASUS Eee PC 900 PC Notebook
My Asus EeePC 900 won't boot up. The lights come on when I press the power button, but the screen remains blank. I can't hear the machine powering up either. I've tried several things that I've read on...
You possibly could connect it to a monitor or tv to see if it shows up on there. But, yea sounds like you have an internal problem with the screen disconnected.
Jan 06, 2010 | ASUS Eee PC 900 16G Notebook
ASUS eee pc 1ooo H doesnt start from time to time !
the blue light is your Wi-Fi
make sure you havent put the machine into "suspend" mode by accidently pressing Fn-F1 or Fn-F5 which toggles between screen and external monitor
Nov 19, 2009 | ASUS Eee PC 1000H Laptop
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
My asus eee 900 pc with 512mb of ram, i upgraded to 2gb of ram, and it restarted fine, now with either ram chip in it it will start to boot up, but the screen stays blank and it attempts to start up with a...
request you to check speed of 2 gb ram with old 512 gb, if u r using 2 strrips of 1-1 gb then first remove both and resinstall old 512 again, and checked, again install both 2 gb ram and check. if after installation of 2 gb ram laptop is not restarting the problem is only with speed of ram. u may need to install ram with proper matching speed
May 26, 2009 | ASUS Eee PC 900 PC Notebook
ASUS Eee PC 900 Notebook Logo
688 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
