Water just keeps running and will not cycle, it will how ever if you do it by hand, have had a flooded basement now twice
You have a faulty float switch and possibly timer
the float switch is located inside the tub fill area Unfortunately you cannot get to it without removing the housing
if your washer has different load levels...small medium etc try setting on small load
If you are handy you can remove the housing to get to the float model
also check the solenoid that controls the water
where is float switch located
already tried the small load thing, but thanks I will
check the others.
Thank you very much
