Question about Lexmark X125 All-In-One InkJet Printer
How do i recieve faxes?
I have a lexmark x125 fax machine and it is plugged into a single number line.i am trying to recieve faxes but they aren't coming thru.is my setup wrong...if not what am i doing wrong?
I am having the same problem with my Canon MX310. I think you have to set up a DRPD (distinctive ring), but I don't know how to do that. If I find out how to fix mine, I will come back to you and let you know
Posted on Jan 06, 2009
Before I moved, my Lexmark all-in-one printer worked perfectly, but after I moved, everything worked EXCEPT printing of an incoming fax. Everything sounds the same through the sounds the telephone makes as...
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X125 User's Guide.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 14, 2011 | Lexmark X125 All-In-One InkJet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
Need to know how to work fax machine for lexmark x125..need a manual..
First make sure the phone line is connected to the in on the fax machine. Then make sure you document is facing upside down. With the top going down into the fax machine. Collate the papers before doing this. If they are not collated they will jam up. Then there should be a scan and fax button or in the menus somewhere hit that option. Enter the telephone number where it you like for it go. Ffinally it the enter button.
Nov 23, 2009 | Lexmark X125 All-In-One InkJet Printer
Cant recieve faxes or fax out
try a different line out of wall or have your phone provider check the line
Mar 17, 2009 | Lexmark X7170 All-In-One InkJet Printer
X9575 fax & recieve phone calls
Yes most of the Lexmark printer work on the same formula ...
Good luck ....
Dec 05, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Calls to my home is pickup by fax
Here is a link to a pdf file version of your instruction manual:
http://www.lexmark.com/publications/pdfs/x125/eng/enogwin.pdf
You will need a pdf reader like acrobat reader or foxit reader to be able to view this file.
You need to change the number of rings before the fax machine answers your phone in order for you to answer the phone first, if you don't use the fax part of your machine simply unplug it from the telephone socket.
Aug 28, 2008 | Lexmark X125 All-In-One InkJet Printer
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X125 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
