Question about Maytag Neptune MAH5500B Front Load Washer
Maytag front loader will not finish spin cycle gets stuck at 9 mi
Spin cycle will go down to 8 minutes then goes back to 9 minutes will continue to run can anyone help me with this problem thanks Cliff
  • vacl Jan 07, 2009
    My washer still has water in it when it turns off. The clothes at very wet. When you place it on spin to try to get the water out. It starts at 10 minutes goes to 7 or 8 back to 8 runs for a very long time and the clothes are still wet.
  • Anonymous Mar 13, 2009
    Mine is stuck at 7 minutes.
  • 7 Answers
SOURCE: Maytag MAV7650
check the lid switch, just replaced the spin bearing on my maytag atlantis washer, mav9750aww, if i called the repairman to fix it, for the money they would charge on replacing this part i could of bought another washer. so i made a website on how to do the job with step by step and with lots of pictures. since it basically takes apart the whole machine, if you are replacing another part you could use this how to to get to the parts. i hope this helps who ever needs it
http://www.geocities.com/maytagrepairwasher/
Posted on Apr 07, 2008
VOTIT
  • 2071 Answers
SOURCE: Final spin cycle issues
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
HOPE THIS MAY HELP YOU;
Regards,
VOTIT
Posted on Sep 07, 2008
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
SOURCE: MAYTAG MAH5500BWW Fails to spin properly clothes wet
I replaced the motor and circuit board but that did not fix it. I changed the out of balance switch and the shock absorbers or snubbers. I think the ultamate fix was the snubbers. it has worked great since. They wear out like your car shock absorbers allowing the drum to shake too much triggering the out of balance switch to stop and restart the spin.
Posted on Jan 24, 2009
  • 30 Answers
SOURCE: what will the Max Extract button do?
The max extract button will do an extra spin to get any & excess water out of the clothes. It is a good thing to keep on to help cut down on drying time. If you find standing water in the washer, it is possible the hose is NOT in the correct position.
Posted on May 03, 2009
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Clothes still wet on Maytag Neptune Front load - only light load
any front loader should be operated with more than on piece of clothing in it. otherwise it is unable to balance the load.
Mar 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Digital control panel is blinking on my neptune front loader!
My screen blinks when the room is cold. If we warm the panel up with a heating pad, it works fine.
Jan 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
