Question about Microsoft Wireless Optical USB/PS2 Mouse (X0872982)
Microsoft Wireless Optical USB/PS2 x08-72982 - I just want the wheel to let me scroll up/down. It's very sensitive and pressing it gives me that free-scrolling icon which I don't want. How do I disable the wheel from doing that when it's pressed?
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 27, 2009
How do I make my scroll wheel work again? It just quit working. Now, I have to click the wheel and move the mouse up or down and it scrolls the page on its own. Nothing happens if I roll the wheel.
If you turn it over you should see 3 or 4 screws in a recess. Sometimes they are covered with stickers. Take the mouse apart and you will see the wheel mechanism and sensors. Clean all the inside with a soft brush.
Or
You could just throw it away and buy a nice new shiny optical wireless mouse.
Did you reboot the computer?
Nov 20, 2015 | Belkin Mini Wireless Optical Mouse...
Microsoft wireless mouse 1000 fix scroll wheel
I had a scroll wheel problem with my Microsoft Wireless Mouse 1000 and fixed it as follows.
With the corner of a sharp Stanley knife blade, I carefully peeled off the large pad at the back of the base of the mouse and removed the two screws that are hidden under it. Next I removed the screw located under the batteries. This allowed the top and bottom of the mouse to be separated. I cleaned out the inside with a small paintbrush and then sprayed a small amount of isoproplyl alcohol into the sensor at the right of the wheel. Now it's as good as new.
Aug 27, 2012 | Microsoft Wireless Optical Mouse USB...
I have the wireless optical mouse blue x08-72982. I can't find the USB connector. What do I buy from Microsoft? What is the name of it?
You will have to buy a whole new wireless mouse. The USB is hard coded for the mouse to a specific ID / frequency. You may find one that works, but it will be like a needle in a haystack and the USB receiver would cost almost as much as a new mouse.
Chris
Jul 07, 2011 | Microsoft Wireless Optical USB/PS2 Mouse...
My new Microsoft mouse is not working. how can I reset it?
just check the usb or ps2 port is working properly,, or else check it with some other PC,, to make sure,, the problem exists in mouse,, or else in your PC usb ps2 ports..
Sep 28, 2009 | Microsoft Wireless Optical Mouse
The exact same problem
Roll back the mouse driver:
1. Right-click [My Computer]
2. Select [Manage]
3. Select [Device Manager]
4. Locate your mouse on the right windows and press the +Mice ...
5. Right-click HID - Compliant mouse ( or whatever)
6. click [Properties]
7. In the "Driver" tab, Select [Roll Back Driver]
Mouse is now free from Microsoft trap....
Sep 19, 2009 | Microsoft Wheel Mouse Optical PS/2 USB...
When I scroll with the wheel on my wireless mouse 3000, two pages go by instead of one
go to start>settings>control panel>printers and other hardware
you can djust the sensitivity of the mouse to slow it down. If this doesnt help you then the wheel on your mouse is bad and you will need to replace the mouse.
Jul 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Mar 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Laser Mouse 6000 v2.0 Scrolling has gone awry
This may not be a solution for you but at least it may explain the cause of the problem. I recently had the same problem - the scroll wheel suddenly began to go crazy, jumping all the way to the bottom or the top of a document, or randomly skipping around. The unit was still under warranty, and Microsoft sent me a new mouse. Since they did not require me to return the old mouse, I decided to take it apart to see if I could find the problem. I found poorly soldered electrical joints to the optical sensor & LED which convert the scroll wheel movement to electrical signals. After I resoldered these connections the mouse worked fine again.
Feb 03, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Computers & Internet Logo
337 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
