Prints too light
SOURCE: Dell P1500 Printer does not print Mriscroft Calendar gridlines
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: Dell P1500 Laser Printer
You need to replace the separation pad. This printer is made by Lexmark, so parts are available through many vendors. The part number for the pad is 56P0691. You can google the part number to find a vendor closest to you for the best shipping charges. It is relatively easy to replace. Good luck.
SOURCE: dell p1500 printer when printing a page, half
HOLA NECESITO EL SOFTWARE DE LA IMPRESORA DELL P1500 ME URGE CONSEGUIRLO LLEVO MESES BUSCANDOLO POR FABOR AYUDA........
GRASIAS
SOURCE: Lights on Dell P1500 printer
Follow the link below and reinstall the device. If the problem still persists then it may be a hardware problem that requires some components to be replaced.
Installing Devices on PCs and Laptops
