Question about Amana ASD2326HE Side by Side Refrigerator
SZD27MW - Freezer Fan not working - temp runs 40 midway in freezer
Amana Side-by-Side Refrigerator SZD27MW The bottom of the freezer compartment will keep ice frozen, top portion is warm 38-44. Refer section stays at 50. Freezer fan does not come on, there is a fan going by the condenser coils. Tried unplugging the freezer section thermostat, and jumping the wires, that did help. Any ideas? What voltage is across the freezer fan?
    Novelist:
  • 87 Answers
Voltage is either 240V or 110V either way it is stamped on the fan motor. You have a sensor controlling the fan and heater which could have gone open circuit and on some cabinets they use the neutral through the heater to bring in the fan so you could have a heater gone. You can bypass the sensor but this should not be a long term solution as it is a safety mechanism. Hope this helps.
Posted on Aug 17, 2007
Amana fridg runs gets cold then won't come back on. And starts depfrosting
If this is "side by side" make sure that you haven't blocked the vents between the freezer and the refrigerator compartments with too much food. The refrigerator compartment is totally dependent on cold air from the freezer and if those vents are blocked, odd things begin to happen. Hope the solution is this simple.
Oct 06, 2014 | Amana Refrigerators
Amana ARB2517CC Freezer is running same temp as refrigerator 45-50 degrees. Any thoughts?
Check your coils underneath for build up, check the condensor fan to see if it is running underneath, check your evaporator fan in the freezer. good luck.
Aug 26, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
I have an Amana BC20TW refrigerator with a bottom freezer. It seems to be running all the time. I raised the temperature dial to make it warmer and it still runs too much. Put velcro on the bottom freezer...
Accuracy is important --Use a digital thermometer to monitor freezer and fridge temps. Fridge should be around 40 and freezer around zero and then take it from there and draw conclusions
Sep 22, 2017 | Amana ARB9058CS Bottom Freezer...
Everything in the freezer has defrosted, temp setting at 6 (refrigerator compartment at 5). Amana bottom freezer model ARB210AB Water will not freeze, ice cream melted and frozen veggies and meat have...
Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
compressor not working
condenser not running
freezer fan not running
thermostat not sensing temp.
stuck in defrost
heaters on too long
bi-metal shorted
timer not working
now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
Mar 27, 2010 | Amana Easy Reach Bottom Freezer 20.5 cu....
Amana evaporative fan intermittent
I would first suspect that the fan motor shaft just has gunk on it keeping it from starting -- clean & lubricate both ends of the motor.
If this doesn't solve the problem, it's the motor start capacitor -- could be inside the motor housing or could be outboard, connected to it via the wiring harness. A capacitor is a lot cheaper than a fan...
Charlie
Aug 31, 2009 | Amana ASD2625KE Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerator warm but freezer is fineChanged the evaporator fan (12013211q)for BR18Ve Amana...Is it possible that the part last only a couple of years...
If your bottom freezer has ice build up, (you will see it frosted up), you do not have proper air flow. Check to see if your defrost elements are working. They are in the freezer compartment. in the evaporator. There is a defrost timer on the bottom of your fridge. You can turn the knob until the refergerator turns off, then listen in the frezzer compartment to se if the elements are working. (You will hear them sizzle)
Aug 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana ASD2326HE Side by Side Refrigerator Logo
249 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
