Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | SAMSUNG MODEL HLN...
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
SAMSUNG MODEL HLN617W TURNS OFF BY ITSELF
By bassman5146 on Jan 06, 2009
This television will turn off by itself after being on for a short period (3 or 4 minutes) I was told that the problem might be the digital board( the board in the center of tv when cover is removed ) but @ $280.00 I thought I should get a 2nd opinion. there are 2 things that might be helpful in the diagnosis
1) After the set is powered up, the fans or color wheel seem to shut off, for a split second, then back on the set works fine 3 to 4 minutes then shuts down. TV cools off for 5 or 10 minutes, I turn set back on and cycle repeats
2) There also is an arching sound that is coming from a component on what seems to be a Hi Voltage board on the right side of tv above the large cooling fan this component also glows sometimes, ( is this normal?)
See Component on board.
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Answer
What's happening is power up chime, and faint volume. I can change channels. Meanwhile, no pic,... (More)
Answer
I have a Samsung HLN 617 W and I turned it on today and it worked fine then later this evening we... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
