Question about GE Nautilus 24" Built-in Dishwasher
Nautilus dish washer won't drain - GE Nautilus 24" Built-in Dishwasher
  • lezli Jan 07, 2009
    GE Nautilus dishwasher won't drain. Drain is not plugged.????
  • cesarini Feb 01, 2009
    water is not completely evacuated after end of wash cycle.... can't see where the filter is inside to remove and wash. help?
    Scholar:
  • 160 Answers
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    ok.
Posted on Jan 06, 2009
I've had my Nautilus for 6 years and it cleans very well - but now, it won't drain fully and pools at the bottom of the unit. I have made sure that my garbage disposal was cleared first, too. and that...
If your model has the screen across the back with the filter, then yes use your fingers or a plier to unscrew the pop up valve assembly at the very back center of the dishwasher. Most likely, the cone shapped part has deteriorated and is not sealing properly, allowing water to flow back into the tub instead of all going out the drain. Replace the pop up valve assembly.
Feb 03, 2011 | GE Nautilus 24" Built-in Dishwasher
The water will not drain from the dish washer and there does not seem to be anything blocking the drain. I ran it through another cycle and now it is leaking water slowly. Is there anyway to drain this...
I would suggest removing and cleaning the filter sometimes debree and build up of small particals can stop it from draining. Clean the filter in hot soapy water and then replace it in the dishwasher and run the dishwasher through a cycle, this worked for me.
Jan 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Water keeps backing up on to my counter top from a drain on the sink. WHY?
If you have a built in disposal in your sink, the perforations in the disposal screen are too small to let the water exiting from the dish washer's pump to go down the drain fast enough, or the perforations are clogged sometimes. The answer is to put a sink stopper in the drain of the sink, which will block the back flow.
Jan 01, 2011 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus- model GSD3400G00WW. Why is there standing water after the dishwasher has completed it's cycle?
i won,t too buy a g.e. dish washer model.gsd3400g00ww where can i find this model and how much it cost.
Nov 10, 2010 | GE Nautilus 24" Built-in Dishwasher
When the dishwasher drains water backs up in both sinks and floods out the vent at the sink?
Hi sound slke ablockage in the waste pipe form the dish washer try some drain clear to clearpipe ?
Dec 17, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Our dishwasher was gushing water after a cycle
If you dish washer pumped or drained water up into you sink then you drain line from the sink or even further down is clugged up, Machine out drain line. A drip sized cable machine can be rented. I recomend a 1/4 inch line. You will only have to go frim the sink to the main line.
Dec 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Dish washer??
Has a disposer been installed recently? If so the drain plug may not have been removed...... Some DW have a check valve attached to the sump that may have a blockage..... Remove the drain hose from the disposer, if connected to one and inspect for blockage.
Jun 01, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus
Check the level of your drain hose underneath the sink between the dish washer cabinet and sink cabinet connect to the dispose position, sometimes if the middle part lower than the dispose will cause the back up problem, should be a little higher.
Apr 24, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
494 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
