Question about Hitachi Deskstar 7K500 500 GB Hard Drive
I have an older deskstar 41gb that I slaved for files and it just died. How can I recover the files from the disk? I think the electronics have failed on the PCB.
  • 331 Answers
Send it to me. TechRx, Inc. of Wisconsin. Data Recovery company. Offering free estimates. We have specific tools that emulate the pcb's of hitachi and makes for simple recovery of your data.
Posted on Jul 23, 2010
Lost power adapter for Hitachi Deskstar HDP725050GLA360 Exteranl Harddrive How do you recover the data without electricity?
if the hard disk has crashed and the sound when it runs later he failed to be detected by the system, it is difficult to restore the data in it because it was not detected by the computer. The cheapest way is that you replace with only secondhand.
Nov 26, 2012 | Hitachi Deskstar 3.5 - 500 GB 7200 rpm...
How to recover deleted or lost files
Most people may be experienced that a daft error on the program suddenly wiped out all of their work.Is there any way to retrieve files that might be lurking on the hard disk?
I think incidents like this teach us how important making multiple periodic backups can be.
Here are some advice for you:
  1. Do not panic
  2. Turn off the power
  3. Do not restart the machine
  4. Connect the hard disk to another PC as a slave disk
  5. Don't run or write any software on the drive.
  6. Start the File Undelete to scan the correct drive
File Undelete can recover all file types, support for over 350 specific file types including document files, Photo, audio files, video files, digital media files, and more!
100% FREE to try..
Click here to view more information of recovery:
on Apr 02, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
How do i set hds722580vlat20 ata/ide as a slave drive
Since it's an IDE hard disk, you'll have to setup disk jumpers, please check the following image:
josema_sv_0.gif If you want more information please see the installation guide at the following link:$file/Installposter.pdf
Feb 21, 2011 | Hitachi Deskstar 7K250 80GB...
Jumper settings/Deskstar 80 GB/hard drive/9 pin when used as a slave drive?
you can find it from this manuel....$file/D7k250_ps1.pdf
Nov 19, 2010 | Hitachi Deskstar 7K250 80GB...
Look for electronic board or complete hard disk Hitachi Deskstar IDE 120 Go HDS722512VLAT20 in order to read an identical disk for which the electronic board is burnt.
Good luck. Try searching on eBay, and use "contact seller" to confirm that they are selling _exactly_ what you are wanting to buy.
Nov 02, 2010 | Hitachi Deskstar 7K250 120GB...
Hello I have LG 2,5" external HDD HxD2 500 GB when i plug to my computer I get " USB device not recognised " message 1) I test the external HDD in other 3 computers I get the same message 2) I...
> how to recover the stored files There's a chance that the USB-to-disk-drive interface inside the casing is the problem. So, open the case, and disconnect the disk-drive from that interface, remove the disk-drive, and then connect the disk-drive into a desktop computer as a "slave" disk-drive, to see if the disk-drive itself is working, and to see if you can access the stored files. > how to fix the external HDD First, you need to spend about $1 million to create a "clean-room" (as was used when the disk-drive was assembled). Or, search online for a professional "data recovery service", who already have a "clean-room". They can separate the "integrated electronics circuit-board" from the "spinning" part of the disk-drive, and then connect another circuit-board, to see if the original circuit-board is the problem. Or, they can disassemble the "spinning" parts, and try to repair it, just long-enough to copy all the files from the disk-drive. Obviously, not "inexpensive", but it could be your "last-chance" to recover those files.
Oct 05, 2010 | LG Computers & Internet
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Recover Data from Hitachi Deskstar (Model: HDP725050GLA360)
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Feb 28, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Hard disk
first be sure the drive is a vaible drive.....meaning it should be in it;s originbal PC it came out of and able to boot up on the installed OS. If it can then you are in luck..... install the drive you want to copy to as a slave and use a program like DriveCopy or Norton Ghost to copy the entire drive.....or if you are just after select files, you can use the copy/paste method to the drive. By trying yo use the drive in a different PC it will not boot since it has the other PC's drivers on it =( If the drive will not detect in it's native machine then most likely the drive is lost (unless you pay to clean room recover the contents....spendy!) Let mem know if you need more help!
Jul 30, 2008 | Computers & Internet
Open Questions:
Hitachi Deskstar 7K500 500 GB Hard Drive Logo
186 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
