Question about Disney Interactive Adventures in Typing with Timon & Pumbaa for Windows, Mac
Screen display problems when running Adventures in Typing
Installation seemed to work fine on XP machine, but when I run the program, it starts out ok typing the D-I-S-N-E-Y, then changes to a funky x-ray like color scheme. I have set compatibility properties to run for Win95 and tried 256-color. Nothing helps. I ran this program on another XP machine and worked ok.
  • freespiritca Jan 06, 2009
    Yes, I have the same problem. I returned the first game. It was messed up from the start. The seond game worked for a bit then screen went blank and the color scheme was all pixeled and mixed up. The box actually says will work on Windows 98SE and above. I have vista. Any ideas?
    Problem Solver:
  • 6 Answers
I bought this for my daughters back in 2000. Now I find my mother wants to become a silver surfer and she would like to learn how to type letters. I tried using Adventures in typing on her laptop and saw that there were compatability issues. After a lot fo experimneting I found asloution that works every time and is as simple as can be. this is what I did (and printed out for my Mum:-)
Hi Mum :-)
Video problems with Adventures in typing with Timone and Poomba
There are compatibility issues with Windows Vista and this program
To overcome these problems we need to force windows Vista to use an
older Video format (from the days when the program was first published).
A short cut has been created and placed on your desktop.
The compatibility (properties) on the short cut have been set to –
  • Windows 95
  • 256 colours
  • 640 x 480
To create the short cut –
Place the CD-rom in the Disc bay and hold down the Shift key while the the CD-rom boots up. This prevents Autorun.
Now use Windows Explorer to look at the files and folders on the CD-rom.
Look for the Setup.exe file.
Right click on it to create a short cut that will be placed on your desktop.
Go to the short cut and right click on it to select the properties.
Now change the compatibility to the settings mentioned above.
Remove the CD-rom from the disc bay.
This is how to use the program Adventures in typing with Timone and Poomba on a computer running Windows Vista
  1. Do not put the CD-rom in the computer until you are asked
  2. Indentify the shortcut/icon on your desktop to start the program
    Click on this shortcut/icon
  3. When the computer asks for the CD-rom, place it in the disc bay and wait for the program to start.
  4. Use the program as normal.
  5. To quit the program so that it saves the progress you have made – use the QUIT symbol in the program’s screen
  6. When the program has shut-down, remove the CD-rom from the disc bay
Note that steps 1 through to 7 have to be done every time the program is started and stopped.
You will not have to do anything to put settings back to where they should be – Windows Vista will do that automatically.
This is how to stop any program if you are having problems and can not see how to stop it.
  1. Press the following two keys together Ctrl Alt
  2. While holding those two keys down, press a third key – the Delete key
  3. A menu will pop up.
    Click once on the Task Manager option
  4. A new window will open with a list of the programs that are running on your computer. Click once on the program that is causing the problem.
  5. At the bottom of the new window click on End Task
  6. The program that was causing the problem will be shut down for you.
Note that using this method is a sort of emergency stop so it will not save any new work you have done on the program/file.
Posted on Jun 13, 2010
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
HI I am having trouble using ie8.I have been using ie8 for about 2 weeks now on my windows 7.I has been running fine until today.Now when I started explorer today an error appeared " windows explorer has...
If you are using IE 7/8 you can try to run the program without loading any add-ons to see if one of them is causing the problems. To do this, click Start -> All Programs -> Accessories -> System Tools and then click Internet Explorer (No Add-ons).
(You can also load IE without add-ons by clicking START --> RUN and then typing iexplore.exe -extoff)
If those don't work try to re-register IEPROXY.DLL by clicking START --> RUN and typing regsvr32 IEPROXY.DLL and then clicking OK.
When IE dissapears does IExlorer.exe show in the task manager's list of running processes?
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reginout
Oct 08, 2010 | Microsoft Internet Explorer 8
Am getting an error message " Internet Explorer cannot display the webpage when I attemp to access LinkedIn site. Used to work, and now it does not.
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reg in out
Sep 19, 2010 | Microsoft Internet Explorer 7
UFT seems to run with Vista but odd screen
Some XP programs incompatable with Vista; you may have to upgrade UFT...had this prob with a lot of my high $ programs....loaded XP on 2nd HDD, and use it for non-Vista compatable programs.
Mar 20, 2010 | The Learning Company Ultimate Family Tree...
Ie problem
I know exactly what you are talking about, my sons laptop was doing this last summer and mine began doing it a couple of months ago (I have since reinstalled XP). O was never able to get rid of the problem but I was able to work around it by running task manager and going to Processes find explorer.exe and end task, then go back to Applications click New Tasks and type explorer.exe.
The problem seems to be within the use screen because I had my own user account on my sons pc and my desktop did bot do that.
Hope this helped you.
Jan 14, 2010 | Microsoft Windows XP Professional With...
Black screen
Find the program in the installation directory. It might be something like C:\Program Files\The Adventure Company\Microids\StillLife
Now right-click on Stilllife.exe, then click Properties. Click the Compatibility tab, then select Windows 98/ME from the drop down menu. Hit OK and try to run the game again. It should start up just fine.
Jul 18, 2009 | Microids Still Life for Windows
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
Software runs until I power down at next power up software dies.
I would suggest purchasing the version of the Mavis Beacon Teaches Typing v 1.5. It's compatible with Windows XP. I've also looked at the software description and you are able to select the age group of the typing test.
However, if some reason you have to continue with the same version. What error message do you recieve?
Thank You, Raphael
Jan 21, 2009 | Mindscape Mavis Beacon Typing for Kids...
Internal Error 2738
Since you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Aug 15, 2008 | Logitech QuickCam Communicate STX Webcam
Disney Interactive Adventures in Typing with Timon & Pumbaa for Windows, Mac Logo
692 people viewed this question
Top Disney Interactive Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Josh Whitehead
Josh Whitehead
Joseph Hoffmann
Are you a Disney Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
