Was driving to work when the engine acted like it wasn't getting gas when i tried to accelerate from a stop sign. A few seconds later it died. It has power and fuel but the engine won't fire up.
SOURCE: dodge ram van e250 dies while driving
try changing the coil- sometimes they get hot and break down- once they cool off vehicle will start and run until they get hot again
SOURCE: 1990 dodge dynasty
Same thing happened to my '89 Dynasty. Turns out the security system was engaged and this stops the motor from running; therefore. a thief cannot drive away with the car! The system is set by using the power locks or an autolock fob, but not by locking manually. Disconnecting the battery will also engage the security system. To disengage, close the driver or passenger (front) door and turn the key in the lock.
SOURCE: fuel pump, fuel filter???
Had the same problem. Just changed the fuel pump today and now working great. Good Luck!!!!!
SOURCE: 95 Dodge Dakota 4 Cyl Dies
try replacing the coil, my 2.5 did the same thing, and after changing plugs,wires,distributor,rotor,rotor button . the last thing i repalced was the coil and i have not had an issue since. all work was done about 6 months ago.
SOURCE: 2004 Dodge 2500 diesel loses power while driving.
I would remove the tank and check the rubber hose that comes from the fuel pump to the top of the tank/gage mechanism, if there is a crack in the hose it would explain why there isnt much fuel being delivered to the motor, since it will be partly sucking air.
