Question about Acer Aspire™ T180 PC Desktop
How to use key board for paragraph spacing
I don't know how to use the key board for proper paragraph structure
    Scholar:
  • 195 Answers
It's not so much you being able to use your space bar, tab, indent and such. You need a good Software that usually does all the small stuff for you. Microsoft Word is a good software, of course their are alot of other good software too. Microsoft Office, has many good programs like Excell, Word, Access, Paint, Etc. Install Word and you are well on your way. Good Luck.
Posted on Jan 07, 2009
When I hit "Enter" it always double spaces. What do I need to do to get single space?
Your word default is set to double space. You need to find your paragraph setting, depending on the version of Microsoft Office you are using. Once you find the paragraph settings, you need to set it to single spacing and set the "spacing before" and "spacing after" to zero as in the attached picture.
One way to set the option is to hit control-A to highlight the whole document and then right click, and then click on Paragraph.
25547294-44porhhyjuxju0hkakw43rbb-4-0.jpg Good luck.
Paul
Mar 10, 2015 | Microsoft Windows 7 Home Premium for PC
How can i write a paragraph in a short time ?
every one need to apply his or her time properly . so you want to make a paragraph in a short time . at first you have to know the rules to make paragraph . then you need to know how you apply them . if you need more go the this site
Mar 18, 2014 | Computers & Internet
I have a word document with several paragraphs perfectly done, but when I copy and post to yahoo to send as an email the format changes and there are wide spaces between the paragraphs and sentences but...
Word inserts formatting instructions that many other programs can't read properly and sometimes it helps to copy the text into a program that doesn't like Notepad and then copy it again and past it into other simple programs.
Notpad removes most complicated formatting instructions.
You may also have to tell your Yahoo or other program that the text you are inserting is normal text, because when you insert it it may be in Yahoo's heading mode format.
Oct 24, 2013 | Cameras
How to fix line spacing to single space on word pad to type a letter. i have it on single space but still does double space
when in wordpad there are couple of things in blocks
clip board, font, paragraph,insert,and editing
2x spacing will be in the paragraph block its the top row right corner
if u hover your mouse over it reads line spacing click it and change it to 2
that should fixya up
good luck on the letter
Mar 29, 2012 | HP Computers & Internet
MS WORD paragraph spacing
Click on Edit>Select All.
Then click Format>Paragraph.
Make sure "Spacing">"Before" and "After" are set to 0 (zero), then click on "OK".
Oct 11, 2008 | Microsoft Office Outlook 2003 for PC
Line space
If you're talking about Word 2007, it is in the 'Paragraph' box under the 'Home' tab, between 'Justify' on the left and 'Shading' on the right.
Jul 28, 2008 | Microsoft Office Professional 2007 Full...
Getting to the lens
well, frustration is something common in this cases, I don`t have the intention to give you more of this but try to be calm cuz it is always possible that the camera will still have problems even after fixing. That camera is not so expensive so think of that and try this out: the lens structure "cannon" is very delicate, a single flase maneuver and you will be out of the game. Place the parts over a soft material, like a soft clean rag or something like that to avoid falling/crashing problems. If you can identify that very very little motor that moves the lenses in and out, separe ir from the structure or just make sure that motor wont be forced while you work. You might not be able to take it out, in that case try moving the gears so they wont be moved.
the structure is sustained by just one or two metallic axis and then you only have a plastic structure tellescope style...
That structure usually stucks for dirt or problems in the structure, yours is obviously the sand... you dont need to disassemble the structure just try to find a little open space or slot and use an AIR SPRAY like "blowing plus" or some like that, you can surely buy it for about 10 dollars or less in a shop, even better if you can get to some sort of air compressor...
Just need to clean the sand by blowing the structure with clean air of some kind. If you insist too much with the lens structure you could brake it so I would not recommend it. It seems you are already tired so better to try cleaning with air, all the structure and the camera also, air wont give more problems.
best luck to you.
Jun 24, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
ASCII codes
#13 - enter
#32 - space
#27 - esc
#21 - paragraph
and etc.
#14 - shift out
#15 - shift in
May 23, 2008 | Computers & Internet
Dreamweaver CS3
Import Microsoft Office documents (Windows only) You can insert the full contents of a Microsoft Word or Excel document in a new or existing web page. When you import a Word or Excel document, Dreamweaver receives the converted HTML and inserts it into your web page. The file’s size, after Dreamweaver receives the converted HTML, must be less than 300K.
Instead of importing the entire contents of a file, you can also paste portions of a Word document and preserve the formatting.
Note: If you use Microsoft Office 97, you cannot import the contents of a Word or Excel document; you must insert a link to the document.
  1. Open the web page into which you want to insert the Word or Excel document.
  2. In Design view, do one of the following to select the file:
    • Drag the file from its current location to the page where you want the content to appear.
    • Select File > Import > Word Document or File > Import > Excel Document.
  3. In the Insert Document dialog box, browse to the file you want to add, select any of the formatting options from the Formatting pop-up menu at the bottom of the dialog box, and then click Open. Text Only Inserts unformatted text. If the original text is formatted, all formatting will be removed.
    Text With Structure Inserts text that retains structure, but does not retain basic formatting. For example, you can paste text and retain the structure of paragraphs, lists, and tables, without retaining bold, italics, and other formatting.
    Text With Structure Plus Basic Formatting Inserts both structured and simple HTML-formatted text (e.g., paragraphs and tables, as well as text formatted with the b, i, u, strong, em, hr, abbr, or acronym tag).
    Text With Structure Plus Full Formatting Inserts text that retains all structure, HTML formatting, and CSS styles.
    Clean Up Word Paragraph Spacing Eliminates extra space between paragraphs when you paste your text if you selected Text With Structure or Basic Formatting. The contents of the Word or Excel document appear in your page.
Source: Dreamweaver CS3 Help
Feb 06, 2008 | Adobe Photoshop 7.0 for PC
Acer Aspire™ T180 PC Desktop Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
