Question about Radio Communications
Dose not recive well
I have a cobra 148nwst transmits great swr are grea but dose not recive over a mile and weak radios at all
  • Anonymous Mar 18, 2009
    my rci 2990 seems to be getting weak on the receive side, any help.
    Problem Solver:
  • 6 Answers
Get a 4 watt linear booster...that will increase ur range...if youy go over 4 watts the FCC can get u!!!!
Posted on Jan 08, 2009
NEEDLE MOVES ON RECIEVE LIGHT BURNT OUT AND NEEDLE DOES NOT MOVE ON TRANSMIT IN S/RF,SWR OR CALIBRATE BUT RADIO TRANSMITS GREAT..
try blowing some canned air on the knob and switch to remove dust , also try a dash of electrical component spray on them , then see if it works.
May 06, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cb radio transmitting problems
Check your microphone and the SWR on the antenna.
SWR checks or bench checks should be free at a RadioShop or CBshops, and normally they will only charge for parts needed.
May 04, 2013 | Cobra 29 LTD CB Radio
I have a Cobra CB Radio and was wondering if I have it on SRF or SWR or CAL
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjust-
ing the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
You will want to operate on S/RF position.
Jul 14, 2011 | Cobra 29 LTD CB Radio
Well ive got a cobra 29 with a RF85X installed on it, it worked great for awhile then all of a sudden it stop transmitting took it to cb shop and repairman found the problem was a cap or diode which should...
Have you checked the SWR's.. also some caps help with the roll off of stray emissions . hopefully he took out the right one. also if you have low amperage going to the radio. it will cause problems. normal cobra 29 2-5amps and the factory pwr cord is adequate for that amperage now your pulling 80watts + make sure you have more amps to handle it. watts/13.8volts=AMPS needed. soo say if your radio is doing 100w/13volts you will need 7.7amps basically in theory.. amps- good grounds- good swr's that shop should of checked your antenna for free.. we do here in texas.
Jan 04, 2011 | Cobra 29 LTD CB Radio
Need a shop
You may have ant. trouble if the SWR is hi
that feeds power back into the radio and
could damage it,lets hope not start with a
good ant.and maybe the radios are not hurt
to bad.
Good Luck
Sep 02, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
GREAT TRANSMISSION HARDLY NO RECEPTION
need to take it in to have the SWR set on antena
Jan 22, 2009 | Cobra 19 DX III 40-Channels Base CB Radio
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
No transmit or recive but works on pa mode
does this radio have freq? if so you could have turned on causing
a miss alignment with antena.. check all the switches move into different positions and keep keying up, good antena connection?
swr?
tony
Dec 03, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
98 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
