Question about Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television
TV COMES ON THEN AFTER A FEW MOMENTS STARTS CUTTING OFF.
THAN I SHUT OFF TV AND SCREEN IS BLANK. AFTER A FEW HOURS I TURN TV BACK ON AND SCREEN WILL COME ON AND DO THE SAME THING. ANY HELP WOULD BE GREAT.
THANKS MARK
  • M TUCKER Jan 08, 2009
    Is there anyway to check this componet.
    Thank you for the quick response. I will get it checked out. Have a Great Day
    Genius:
  • 2,920 Answers
Have you had any recent power outtages? anything that would cause the problem? if its a nice tv abd worth fixing i would take it in and have it serviced and warrantied so if you have any more problems with it they fix it for free.i would take it to a shop and have it repaired rathre than try to do the fix it youself thing because it could be so many things causing the problem.
Posted on Jan 08, 2009
    Genius:
  • 1,550 Answers
The high voltage sine is shorted and some components are not working properly .
  • SAM ANDERSON Jan 08, 2009
    You cant check at home . You need to call service technican for checking this components . It is very risk to perform this action . I will provide you in detail what they will perform
    The traditional method to check whether sine wave is properly generated is using an Oscilloscope- A crystal oscillator produces a sine wave when excited. It is appropriate then, to see a waveform representative of a sine wave on the clock pins. If the clock is not working properly then the components will be replaced.
  • Sony Master
  • 19,396 Answers
That sounds like a poer board that is failing.
  • Ginko
    Ginko Jan 08, 2009
    If the screen is blank , no raster but there is power than that is probably not the power supply.
    If screen is blank and this is a CRT, then it is likely a problem on the deflection circuit, a cold solder joint, or an IC that is failing.
    If this is an LCD it can be a bad inverter, a bad connector or ribbon cable, or again a faulty component.
    To fix this kind of problems you need to have a technician testing your TV.
    I can be provide more details if I have the TV model.
I had shut my tv off and was working fine before I had done so: I whent to turn it back on a few hours ago and when I turn it back on it goes to a blank black screen.
Sounds like the input might be incorrect? I would turn it on and hit the input button, make sure it is set where you want (for example, hdmi 1).
Oct 23, 2017 | The Computers & Internet
My Viore flat panel tv comes on for a few moments, then the lamp and temp/standby light flashes and the screen goes dark. The picture is just fine for the first few moments, and then it goes dark. Any
this is caused by a bad connection, or a faulty back light. It is also something you should have a local repair man have do for you if you are not "tech savvy".
Sep 23, 2014 | Televison & Video
Starts up goes to start windows then goes off and comes back to start again
It is more than likely the hard drive, or the window files are corrupted, if you have a backup recovery disc try it now, no change! have the hardware tested.
Jun 23, 2012 | HP Compaq Evo n610c Notebook
My sony bravia tv will not turn on, the light on the bottom comes on but the screen is completely blank. i was watching it two hours earlier and i turned it off myself. than it didnt work when i tried...
Do you have...a dvd player a ps3 a box?
Becouse if you have, you need to change the input and maybe you forget to put it right back.
Imagine you have a ps3, you have to change the input from tv to HDMI right..well if stop play or watcha movie and torn off the LCD...when you came again the next day the LCD starts as HDMI and not as TV.
You need to change the input...
Hope it helps, if the problem persists it´s a malfuncion...
bye
Cyber
Mar 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My nuvi 660 sound keeps cutting out, when i tap it it comes back for a few seconds seems like a connection is loose
if you mean the screen just goes blank but the gps is not turning off, go to the tools section (little wrench icon) then system then make sure safe mode is off.
if your 660 is powering off totally, make sure it is fully charged by charging it via the usb cable to your computer for a few hours.
bill
Nov 07, 2009 | Garmin Nuvi 660 GPS Receiver
TV screen tuurniing on and off, sound remains on.
If its a DLP set have you ever replaced the lamp? If not I would suspect that first..
Aug 14, 2009 | Televison & Video
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television Logo
70 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
