Question about Maytag PAV2300 Top Load Washer
Maytag won't spin or agitate
A week back I had a problem that our Maytag (Performa PAV2300) would not agitate, but it would spin. I had a look at the machine, remove the agitator pieces inside the tub, check the belt - really did not do anything, but the machine worked again for 6-10 loads. Today the machine would not spin anymore. The motor and the drum pulley (indirect drive) spins, the agitator shaft and tub does (hardly) not move. Nothing obvious, but I remarked that the tub spins faintly if set to the spin cycle - however without any significant torque. The 'spinning' was more pronounced after I removed the tub. I noticed that the motor is a kind of floating design, it cannot be bolted into place, so 'belt tension' cannot really be adjusted here . That appears to be odd ... Please , any suggestions are welcome !!! Frank
  • Frank Gransee May 27, 2007
    After taking the transmission out I could (and for the first time understanding how the machine works) I could determine that the brake for the spin cycle was not released when the pulley turned ccw. I adjusted the Thrust Bearing Assembly - really just taking it apart and back together - and the machine works again ... for now.
    I am not sure how a worn Thrust Bearing Assembly looks like, this made a good impression (7 yrs old) ... so who knows.
    Frank
  • Anonymous Nov 15, 2007
    agiator and tub doesnt spin ,need plans how too change bell coupling
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
Posted on Oct 23, 2007
SOURCE:
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
PAVT920AWW Noise in wash cycle no agitation
Your Belt still needs replacing or to be scuffed up with sand paper. If thes fails you need either new tub bearings or a transmission. either a 250-300.00 repair so tr the belt and rotate drain pump rotation while the belt is off
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
Maytag Preforma washing machine
I would suggest Service Technician is cheaper than doing it yourself Bev007. It will save you headache too. Depending on the severity of the damage, you'll be working on the transmission attaching the shaft of the pulsator or agitator.
Dec 21, 2007 | Maytag Performa PAV3200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
1,227 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
