Question about HP Pavilion ze5470us Notebook
HP ze5470us memory upgrade not fully recognized
I switched out the two 256Mb memory cards for two 512Mb memory cards, but the computer is only recognizing 704Mb. Is something wrong with the new memory cards?
  • 340 Answers
I am almost sure that you, by accident of course, switched the memory blocs, so that you have put in one 256MB and one 512MB.
Have a look at the once you have on the table.
/Teis
Posted on Jan 06, 2009
  • Teis Thomsen
    Teis Thomsen Jan 06, 2009
    or - maybe the dealer gave you a wrong block.
    /Teis
Is there any specific memory card brand and value for ASUS P4V533-MX? I want to upgrade my computer's RAM from 256MB to 1Ghz, I bought two DDR1 512MB surplus memory cards with different brand name, neither...
This mother board Support only DDR333 PC133 SDRAMS. Check the lebel of your newly bought memory modules whether it matches or not. If not then you should replace them.
Mar 15, 2011 | ASUS P4S533-MX Motherboard
I want to know which memory to buy for my pc. I checked it on crucial.com and it said I could upgrade to 1gb. When I looked inside the cover I saw a 256mb memory chip but could not see how many slots it...
hello, here's a part of the spec from the hp website. It looks like you've got 256mb on board memory and one expansion memory slot in which you can fit a 1024mb card, giving you a max memory of 1280mb (1024+256).
Hope this helps!
nicam49
Hardware
Product Name zv5410US US Product Number PR465UA#ABA Microprocessor 1.8GHz AMD™ Athlon™ 64 Processor 3000+ with PowerNow!™ Microprocessor Cache 1MB L2 Cache Memory 512MB DDR SDRAM (2 x 256MB) at 333MHz Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Video Graphics NVIDIA GeForce 4 440 Go Video Memory 64MB DDR (dedicated) Hard Drive 60GB (4200RPM) Hard Drive Diskette Drive External USB Floppy Drive available for customers via hpshopping.com or local retailers
Jan 11, 2011 | HP Pavilion zv5410US Notebook
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
My Dell Latitude C840 works only with one memory module
Your motherboard is bad or there might be something in the slot preventing the memory from seating properly.Check if there is something in the slot preventing the memory from seatting properly.good luck
Sep 14, 2009 | Dell Latitude C840 Notebook
T22 Doesn't boot on Memory upgrade
First make sure the memory is the same PC 100 , then make sure the chips are fully seated. and try rebooting computer. If you mismatch the Dimms the memory wont be recognized by the computer.
Sep 02, 2009 | IBM ThinkPad T22 2647 Notebook
I wanted to upgrade the memory on my pavilion zt1130 notebook from 256mb so I purchased to 512mb memory cards and replace the resident memroy under the keyboard. It runs faster but as soon as I put the...
According to Hp website your computer will handle two 512 Mb RAM chips. Make sure they are PC133. If computer will not boot with both inserted properly, one of them is bad. Put one in slot 1 and none in slot 2 and see if it boots. Then switch the chips put the extra chip in slot 1 and none in slot 2. See if it boots. This way you can troubleshoot a possible bad chip.
Aug 15, 2009 | Office Equipment & Supplies
Thinkpad T20 won't accept memory upgrade
according to ibm
you are allowed only pc100 memory with a maximum of 512mb.
when handling memory make sure you are grounded before touching any memory chips.
try getting another set of 256mb chips and grounding yourself before installing them.
Mark
May 15, 2009 | IBM ThinkPad T20 2647 Notebook
COMPUTER DOESN'T RECOGNIZE ADDED MEMORY
Are the memory cards the same? Try swapping the memory cards inside the computer. It is also important to go into the Setup (F2) once the new memory has been added. The setup keeps track of the hardware changes to your computer, and the additional memory needs to be saved in the Setup configuration. Please let me know what happens and thank you. Binary Bob
Dec 27, 2008 | Dell Dimension 1100 PC Desktop
HP Pavilion ze5470us Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
