Question about Canon BubbleJet i550 InkJet Printer
Failed to print
(error message) Printer not responding. Paper thickness lever position. I have tried cleaning the print heads. Electrical contacts and ink inlets and outlets. I tried reinstalling the print program "drivers". I shut off and restarted the computer. I tried printing with the print head out. I get the same errar message. I changed the data cable. Do you have any sugestions? Mike Nevins
  • Michael Nevins May 26, 2007
    One other thing. Obviously I moved the paper thickness lever back and fourth several times, and tried printing in different positions
  • Michael Nevins May 31, 2007
    If you had read my comments you would have seen that I did try moveing the paper thicknes
    lever back and fourth. That would not be the problem unless there was some a unseen buildup of some kind behind the lever. Logic tells me that there is a sensor that is dirty or not working properly. I have cleaned everything in sight, but I don't know where it is.
    I have another printer, so I'm not without one.
    What I need is infornation. I like this printer, and have just bought a lot of ink. A schmatic or something that tells me what generates this error message would be healpful.
    Mike N.
    Genius:
  • 2,985 Answers
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
Posted on May 28, 2007
  • john ash
    john ash May 31, 2007
    take a look at
Canon MP600 printer, error msg. U052 Cleaning the printer head doesn't help. Replacing with new (full) cartridges doesn't help. The only one thing, that helps now, is to disconnect the printer from power...
Description
Reseat the Print Head to resolve the U051 / U052 error.
Solution
Errors displayed on the printer's LCD screen:
  • U051 Print head is not installed. Install the print head.
  • U052 The type of print head is incorrect. Install the correct print head.
Reseat the Print Head:
  1. Make sure that the power is turned on, and open the Paper Output Tray gently
  2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
  3. Remove all the Ink Tanks in the following manner.
    1. Push the tab (B) and lift the ink tank to remove.
    2. Do not touch the Print Head Lock Lever (C) while removing the ink tanks.
  4. Once the ink tanks have been removed, raise the print head lock lever.
  5. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
    *Before proceeding to next step, check the carriage area for packing material, torn paper, etc. and remove if found
  6. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
  7. Insert ink tanks into the print head.
    1. Insert the front end of ink tank into the Print Head at a slant. Make sure that the position of the ink tank matches the label.
    2. Press the mark (Push) on the ink tank until the ink tank snaps firmly into place.
      Make sure that the ink lamp lights up red.
  8. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Note: When the next printing begins, the print head cleaning will begin automatically.
If you have reseated the ink tanks and print head and the error still appears, our industry-leading support team is available to help you Monday through Friday from 10 AM to 10PM EST. You can contact our technical support experts by phone or email:
Call 1-800-OK-CANON (1-800-652-2666)
May 06, 2017 | Canon PIXMA MP600 all-In-One InkJet...
Canon i560 colour printing problem
have you tried changing the cartridge..?
Jul 29, 2008 | Canon Office Equipment & Supplies
Blinking 1 green 7 orange and not responding to any commands
It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
YBC (/\)
Nov 09, 2009 | Canon i950 InkJet Photo Printer
Canon i550 yelow light on: "operator error" . Have tried to resume and delete printing tasks and restarted printer
Had the same problem with my I550. Was going to buy a new printer (I4000) since I could get one for about $30 more than the price of a new print head. I like canon printers with the individual ink tanks and have had no problems with the I550 for about three years.
Decided to try moving the paper thickness lever back an forth a number of times since some of the error messages indicated it could not determine the setting of the paper thickness lever. I don't know how the printer determines this switch setting but I thought if some contacts are slightly oxidized that movement might break up some of the oxidation. After operating the lever about a dozen times the printer started working. Hope this will help.
Oct 12, 2009 | Canon BubbleJet i550 InkJet Printer
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Canon SmartBase MP360S printer
You have Vista this is the problem- there may be a driver issue here
take a look at
http://www.google.co.uk/url?sa=t&ct=res&cd=3&url=http%3A%2F%2Fwww.opendrivers.com%2Fcategorycompany%2F1405%2F129%2Fmultifunction-canon-free-driver-download.html&ei=DvyBSL7IOZ3uQo-KpLYN&usg=AFQjCNExG7VOz91yswKZfouV8puBHufbKQ&sig2=gL2G5p7ndcDLosNQmPsh4w
Jul 19, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Paper Thickness Lever
there is a part we could it mask its piece of metal in front of the head clean if the problem dos not solved tray to change
Mar 22, 2008 | Epson LQ-2180 Dot Matrix Printer
Printer won't print
I know that the paper lever is where your paper is loaded. Check the grey plastic tab and try to drag it to the right or left. Depending on your paper size you might have to check the owners manual.
Mar 03, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i550 InkJet Printer Logo
613 people viewed this question
Clive
Clive
old marine
old marine
