Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My Maytag Side by Side is stuck in Auto Defrost
Can anybody tell me what I can do to fix this?
  • 15,935 Answers
Cold control thermostat is your most likely component to fail.
please go to this site since you have not entered in your model # and enter it. Search for the part you need "cold control thermostat"
Posted on Jan 06, 2009
Side by side refrigerator not defrosting
you should probably call a technician. the possibilities are many:
Defrost time is stuck, defrost heater is out, defrost thermostat is bad. defrost timer is part of the icemaker and therfore, icemaker is bad etc. it is rather difficult to diagnose without knowledge or proper tools
Jan 06, 2014 | Maytag Refrigerators
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
Freezer not auto-defrosting; replaced defrosting coils. What controls them?
Hi welcome to fix-ya. The defrost is started when white sensor located top of coil left side. That tell the motherboard to defrost. When done the same sensor shuts down defrost. The defrost termintor that is wired in line with heater is only for safety. I hope this helps.
Sep 18, 2011 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
I have a Maytag side by side refridge Model # MSD 2436GRW The refirdge side does not feel like it is cooling properly- I have had to move the dial up tp 8-9
There are many different ways a refrigerator will do this. But I will focus on the most likely and that will be either the 68233-2 Defrost Timer or the=> 61005989 Auto Damper Click Here=> MSD2436GRW_Controls and in that photo you will see the location's 13 and 8. Here are the instructions for testing the auto damper=> 61005989 Auto Damper Test Instructions Look into the rear of your freezer and tell me if ice or a layer of frost is covering the rear panel. If yes try to turn the defrost timer clockwise slowly untill refrigerator stops or manually defrost with a hair dryer. If the refrigerator defrost after turning defrost timer then just replace timer. Refrigerator will usally take 25 minutes after that time the refrigerator does not come on simply turn th timer clockwise until it starts. If defrost is not the problem then it is time to test the auto damper. There are a few other test like testing the defrost heater= HERE Here is the freezer compartment parts breakdown=> MSD2436GRW_Freezer_Compartment and part 12 in that photo is the=> 61006116 Defrost Heater Assembly with Defrost Thermostat
I will be here on Fixya or Here if you have questions, Thanks Sea Breeze
If helpful please rate this solution.. Thank You
Jul 19, 2011 | Maytag Refrigerators
Our zigzag side by side is freezing up product in the refrigerator section. Even with the digital controller set to to its warmest level of 1. I suspect it may be the something to do with the air damper...
the wide x side if freezing up is controled by a microprosser . and it had prob failed and is not controling run time of compressor or the defrost cycle . need a complete model # and ser to hepl more if needed mm . feed back pls .
Dec 11, 2010 | Maytag ZigZagW / B Side by Side...
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
How do I check the heater under the evaporator in my Maytag wide bt side and how do I replace the heater unit?
I am sending the manual and on page 45 at top of page ans section 2-17 tells you the way to change or test the defrost controls. All refrigerators that have auto defrost begin with cotrol/timer/adaptive defrost or Adaptive Defrost made into motherboard, Then you have the defrost heater and defrost thermostat. When looking over your manual you may see things that are not on you model. That is normal or we would have a manual for every difference.
Mar 21, 2010 | Maytag MZD2752G Side by Side Refrigerator
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
Defrost for Maytag side by side
To access the heater circuit you must remove shelves from freezer, defrost the back panel with a hair dryer. Remove screws holding the panel in place and remove the panel. Defrost any ice on coil. This will give access to the heaters and defrost thermostat. If the defrost thermostat is deformed in anyway such as bulging at the molded part the chance is that that is your problem. Reading through the heater circuit with an OHM meter will tell you if the heater(s) are open. If you get an open reading replace the heaters. If this is above your capabilities call a service tech.
May 25, 2008 | Maytag MSD2756G Side by Side Refrigerator
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
