Question about GE Spacemaker JVM1640SJ Microwave Oven
Annoying "hum" in GE JVM1631WB002 microwave
I have a hum that is coming from the pwer supply/transformer on the PC Board in the unit. The replacement PC Board (part PT6078474) cast in the $125-$130 rande. Is there a way to just replace the power supply that is "humming" without replacing the entire board. At $125, let it "hum"!
  • crecord1 Jan 06, 2009
    I think the part number above is specific to a parts website I was on. I think the part is typically referred to as the "PC ASM" by GE. I have also seen part #WB27X10257 for the panel.
  • crecord1 Jan 09, 2009
    Do you have the ability to advance ship a repaired unit and then have the old one sent back to you? That way my wife isn't without her microwave.
  • GE Master
  • 9,098 Answers
The correct GE part number for the smart board (printed circuit assembly) would be WB27X10257 but I would not go to that expense.
A pretty common problem on these GE by Samsung units is a leaky electrolytic filter capacitor like the one shown in the photo.
Annoying
That's the fix, to replace the biggest capacitor, in this case.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
  • William Miller
    William Miller Jan 10, 2009
    Yes, in fact I do have one. It has been refurbished and tested.
    It would run $59.95 postpaid if you'll be sending your board to me after installation.
    I can accept check, money order, or PayPal.
    Feel free to contact me directly and please remind me of your
    full model number as well as this post's URL.
    We're
    William E. Miller
    prototech@usa.net
    P.S. I hope that will earn me a "FixYa" rating, too!
Have GE built in microwave on top, oven on bottom. Microwave stopped all sudden, changed out fuse and comes back on but soon as press start button..fuse blows and unit stops..need help troubleshoot
If the unit shorts when you push start. it is something shorted in the high voltage section of the unit. The HV section is made up of 4 parts. The High voltage transformer, the Capacitor , the rectifier / diode. and the magnetron. If the mag shorts it will just hum loudly and not heat, so Your problem is probably the capacitor or a shorted transformer. More commonly it is a bad capacitor. If you have an ohm meter, check the capacitor. It should not read shorted. If it does that is your problem. If so replace the rectifier too just for good measure.
Sep 23, 2017 | GE Microwave Ovens
Tip
Micorwave ovens - and where's the heat?
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout and you can get the various functions to work, just no heat)
2) Failed door switch
3) Failed thermal fuse, when used
4) Blown power fuse that is dedicated to the microwave circuit
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Door switches insure the microwave circuit will not engage when the door is open. Slamming the door of the microwave is hard on the switch.
The thermal due is wired into the microwave harness, and is a melting allow type, based on heat buildup within the oven. Always replace with a fuse of the same thermal rating.
The power fuse is a special type and should only be replaced with that same type and rating. It is easily tested.
The diode is a relatively inexpensive part, and is not easily tested. If a grumble is heard coming from electrical area of the unit, then the diode could be shorted.
A shorted capacitor will blow the fuse immediately. And open capacitor will cause a "no heat" condition.
A bad magnetron will also cause a low level hum or grumble from the transformer. But is may also cause no other identifiable symptom of failure.
A bad transformer will exhibit a grumble or hum, and may or may not blow the fuse. But be careful here, the secondary of the transformer produces very high voltages, up to 2.5Kv. Few people own a meter capable of measuring such voltages.
Service and repair of microwave ovens is dangerous work. If you don't know what your doing, DO NOT ATTEMPT TO SERVICE A UNIT WITHOUT INSTRUCTION.
on Feb 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a "continuous" humming sounding when units are heating. The sound is very loud
The humming sound that occurs may be similar to the annoying buzzing my GE microwave produces at random. It could be mechanical vibration. Doesn't seem to affect cooking.
Nov 16, 2016 | Microwave Ovens
JVM 1440 GE microwave stopped heating. all other functions work great. where do I start
GE microwaves are notorious for the magnetron failing, this is what generates the microwaves. Usually the unit will make a louder than normal deep hum when running if this is the case, but not always. If you have the schematic, you can measure for 120 volts leaving the control board to the transformer, you can simply measure the line in on the transformer for this. You also want to visually note that all other functions like the countdown timer, inter light, turntable, and fan are all running when you start a cooking cycle. The monitor, and interlock switches mounted on the latch assy need to be checked for continuity too. If replacing the magnetron we always recommend replacing the high volt diode connected to the capacitor and chassis ground. Pleazer Appliance...
Jan 14, 2015 | GE Microwave Ovens
Microwave buzzes when off
This is the power transformer humming, sometimes when transformers get older you get vibrations in the windings due to magnetic fields generated within the transformer which causes the humming noise, It's more annoying than anything and won't affect the operation of the microwave.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Turns on but no heat. ? is there a fuse we can replace and where is it?
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Jan 16, 2011 | GE JVM3670 Microwave Oven
It made a loud pop while heating. Now everything works but the microwave does not heat. What is wrong and how can it be fixed?
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Jan 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When the microwave is plugged in but not running there is a buzzing/humming noise.The unit works fine and the buzzing/humming continues when in operation as well.
That noise you hear is loose laminations in the standby/controll transformer. It is no more than a nuisance.
The transformer can be replaced by contacting the manufacturer and browsing for a dealer near you.
Hope that helps.
Dec 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Chefmate microwave will not heat up anything
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
494 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
