Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Craftsman 3/4
Can you help?
My gears were finally shredded on my 15+ y/o Crafstman 1/2hp motor - so I replaced it with a 3/4 new model. I left the door hardware and simply replaced the motor, kept the chain. I have a 15 ft wooden door.
It worked very well for about two days after I had dialed it in using the force/travel adjustments, but yesterday, it started bouncing up off the floor. I turned down the down travel as far as I could go (and it still bounced). It looks like its really pushing hard when the door is closed, then reverses.
I played with both force and travel - and nothing seems to work.
The upward travel works like a charm, I can dial that in to stop 2-3" from the stop bolt - and it works as it shoud. Down travel seems "broken."
Any thoughts?
  • tvaughn243 Jan 09, 2009
    It was a new motor - so I assumed that it was right when it came to me in the box. I opened up the case, and sure enough had a broken part.
    The small metal "t" that travels between the up and down travel limits was broken. Travel assembly was replaced - and door works PERFECTLY.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Open up the caseand look at the travel assy. Sometimes the limit (up or down) do fall off the assy. Just snap it back on.
Posted on Jan 09, 2009
Looking for Bevel Gear
I would email them and ask if they have a substitute for the part number GBF-512 .
Jun 09, 2014 | Olson Bi-metal Bandsaw Blade 80 Inch For...
I need the sway bar bracket number for mower 917-272263
The parts lists for the Crafstman 917.272263 mower is available here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917272263/0247/1509200?shdMod=917.272263&sid=C2CxSPDxModelSearchxModelNotoSPD . The Sway Bar Bracket is on the Mower Deck diagram (part 3) is part number: 138017 . Sears Parts Direct lists this part as backordered. However, a vendor at Amazon does appear to have it in stock. See http://www.amazon.com/Husqvarna-138017-Bracket-Assembly-Craftsman/dp/B0057ILJAA ; this bracket fits several mowers, including Sears/Craftsman mowers.
I hope this helps.
Apr 21, 2012 | Garden
I have a Sears Crafstman Garage door wireless opener. Model 139.53615SR . The door hums but nothing happens. The chain doesn't move. The springs on the door broke last year and i replaced both of them....
My plastic gear stripped soon after a spring broke. I think the broken spring put a huge load on the opener that day and ruined the gear. Replacement wasn't too hard. It will be obvious when you remove the cover if the gear is stripped. Here are instructions:
http://tinyurl.com/gearfix
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My crafstman garage door opener goes down and then
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remove the cover and check the drive gear. It could be stripped.
Mar 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Crafstman 41A435-7A
If the board you say is broken is the one you got the part #41A4315-7A, that is the part number you need. You can get it at Sears or any good door service company.
Sep 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman garage door opener and just replaced the plastic gears. I followed the step by step directions but the door is now only opening 2-3 inches, reversing and then going back down. any ideas?
I managed to troubleshoot this myself and got my door working. The problem was that the black rpm wheel was not far enough down on the gear shaft. By unscrewing the screws on the final piece of the assembly on the shaft and then pushing it all more firmly toward the motor and rescrewing in place, I made it so the door operates beautifully.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp opener
I am sure that your lift gears have stripped and need to be replaced.
Sep 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Sprocket replacement procedure
You need a gear kit. Amazon sells them. I got mine at a Sears Service center. Beware that you will need to completely disassemble your unit to replace the gears.
http://www.amazon.com/Sears-Craftsman-Liftmaster-Garage-Opener/dp/B000JGLX9C
Mar 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
147 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
