Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Months ago I installed the SBG900 Wireless Cable Modem Gateway. Now I want to Enable the Firewall. So I put the CD in my drive but am unable to nagivate my way or to Launch Admin Application (which I believe is step one to customizing my firewall settings
  • 1 more comment
  • Seattlesteve Mar 11, 2009
    I can't access the router using the above ip address.  Mac OS 10.5 with Safari and Mozilla Firefox.  I can get online with both wifi and ethernet but can't access router to set up a password.
  • Anonymous Mar 19, 2009
    Trying to enable firewall on SBG900 router. I have IP address but don't have username and password ("admin" and "motorola" did not work). Any ideas?
  • oscar22 Mar 19, 2009
    I have same prob. but username and password dont work
  • 104 Answers
You can enable your router firewall by logging straight into your router, as the necessary software (firmware) is within the router itself.
To login to the router, open a web browser, and type the IP address of the router into the address bar. The default for this router is http://192.168.0.2
You should see a popup box asking for username and password. This are likely to be the defaults: username: admin and password: motorola. Click to login.
If successful, you should now see the router configuration screen.
Click 'Firewall' tab in the left hand screen. From here you should be able to configure the firewall. You can enable it in Policy > Basic.
Hope this helps you, but please come back to Fixya if you need further help.
Posted on Jan 06, 2009
  • eecom Jan 06, 2009
    Important:: use a wired (ethernet) connection to the router when making these changes.
Is the Motorola SBG900 cable modem gateway a router- that is will it enable file sharing between the computers that share the gateway (one wired, one wireless). If so how is this set up?
you should be able to set up a home network you will have to enable file sharing, if you run through the network setup wizzard in the control pannel it should be fairly straightforward
Jan 21, 2011 | Arris Surfboard SBG900 Modem Cable Modem...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Unable to pick up on wifi signal
As you say, you'll need a driver for the modem. I have the site for Motorola Gateway sbg900 modem driver site. See if this help.
http://broadband.motorola.com/consumers/support/default.asp?supportSection=CableModems
James
Mar 26, 2009 | Acer Aspire One PC Notebook
I have a Surfboard SBG900 router and cannot connect to VPN
The issue you have is not due to enabling WPA. It is due to enabling Firewall protection. Either turnoff firewall or use custom option to enable required ports.
Nov 26, 2008 | Arris SURFboard SBG900 Wireless Router...
Vonage ip voice will not work with internal firewall turned on
then iot seems that your fire wall is not compatible with it, try installing a different one, or try port forwarding that will fix your problem
Aug 15, 2008 | Arris SURFboard SBG900 Wireless Router...
Can't open my NAT
Hi there.. i had that problem too and i just solved it...
heres the thing..
first you go into the router setup page.. which is.. 192.168.100.1
go to the gateway tab
go to port forwarding tab
go to config
thenTemplate --> custom
Name--> whatever
Port start--> 88
Port end-->88
LAN IP address--> check on your xbox on network settings and copy the same ip address.
Enable --> checked
Then click add.
After that.. you will do the same thing but on the port option you will put 3074. add it ..
now your nat should be open. ;)
Dec 30, 2007 | Arris SURFboard SBG900 Wireless Router...
Downloading Problem with Motorola SBG900 Wireless Cable Modem Gateway
Sounds like your laptop is hit with spyware and or viruses. Try starting it in safe mode (F8) and seeing if you still have this problem. If it works in safe mode go to grisoft.com and download the antimalware free trial. Restart in normal mode and install and run the trial version.
Aug 05, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
303 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
