Question about Daewoo DV-6T834 DVD Player/VCR
Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
My DVD/VCR combo is flashing a "locked" message when turned on. I am unable to locate a front panel lock button or reset switch, menu is inaccessible as the unit appears to be locked. I find nothing helpful on the remote control either, no lock button or reset switch available there either.
We just unplugged our sony dvd player and plugged it back in and it worked.
Posted on Oct 14, 2009
In the Daewoo manual, it says that the child lock has been engaged and to hold down the power button on the remote for 8 seconds to clear it
Posted on Aug 20, 2007
2 Suggested Answers
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Posted on Dec 20, 2008
Dvd player locked
Press and hold power button to turn off the vcr lock and turn back on player lock will be cleared from displayed.
Nov 26, 2009 | Sony SLV-D350P DVD Player/VCR
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
DVD/VCR Combo is Locked. The read out on the box says LOCKED
You might press the "Childlock" (or something lock) button on the remote control to unlock it. Hope it help!
Oct 19, 2008 | GoVideo Go Video DVD/VCR Combo
Jun 18, 2008 | Apex Digital ADV3800 DVD Player/VCR
Daewoo DV6T811N DVD Locked
Your Child Lock has been turned on.
Press the power button of the remote for about 8
seconds. No buttons of front panel and remote can be
operated now and Lock indicator (“LOCK”) will be
displayed on window display.
To release child lock,
press the power button of the remote control for
about 8 seconds.
Good Luck.
Apr 08, 2008 | Televison & Video
Bush Video Dvd combo Dvrhs02 Lock Code
Turn the unit on then press the 'vcr/dvd' and 'disc menu' buttons on the unit together and hold down until the unit reboots
Jan 03, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Locked DVD/VCR Combo
Hold the power button down for 5 seconds fixed it for me.
Sep 23, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Locked DVD TRay
After working with my technolocically challenged mother on the phone for about an hour we found out that pushing the power button on the remote control and the stop button on the DVD player at the same time will unlock the DVD player. Hope this helps.
Jul 23, 2006 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Samsung tv vcr combo
according to the info I have on that set theres a front panel control key theres also a lcd display?? as I see the picture you may have locked the set with this control key?? if this dosent work go online and look up samsung LTP179DW remote controls or contact samsung directly at www.samsung.com and go to customer assistance. Hope this helps ya!
Apr 02, 2006 | Samsung LTP179DW 17 in. TV/DVD Combo
Daewoo DV-6T834 DVD Player/VCR Logo
820 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
