Blank page prints in between a fax received
I have a Pitney bowes 1640 but when i receive a fax it also Prints a spare page in between.
How can I stop that
Thank you
  • imant_kuda Jan 12, 2009
    Its not connected to a Server. I am sure its some setting on page size on the machine that will solve it.
  • 100 Answers
If its coming from a fax server this cannot be stopped. You should upgrade to a newer better machine that is up to industry standard. Fax servers are basically faxing you from a computer. This is a different process than faxing from an actual fax machine and the page size can be conflicted. Only high end newer machines can compensate for this.
Posted on Jan 10, 2009
  • Mike Jan 12, 2009
    ok have page sizes been verified iin the machine? Sorry i cant offer anything on this one.
Hi. i hope you can give a suggestion with our brother intellifax 2820. Whenever printing a received fax, the machine prints out a blank page in between each received page. so, for example, we receive pg1,...
press "menu/set, 1, then 3. you should see "paper size" on display. select "letter" if thats what you are using, and press "menu/set" again, then "stop/exit" to back out. next, make sure your "fax" button below display is green, then press "menu/set, 2, 1, then 5.using your arrow keys, select "on". press "menu/set" then "stop/exit". that should do it.
hth,
razors
Mar 15, 2010 | Brother IntelliFax-2820 Laser Fax
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How to print Speed dial numbers programmed for Pitney Bowes Fax Model 1630
I believe you press , features 1 , 7 , 3 enter then the send receive key to print.
Aug 25, 2009 | Office Equipment & Supplies
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Incoming Fax is blank
PRESS REPORTS IT WILL PRINT OUT A HELP PAGE LOOK AT THE SUB MENUE ON THE HELP PAGE MENUE SELCTION 3 FOLLOW THE PROMPT TO TURN ON THE RECEIVE OR IT MAY SAY EASY RECEIVE . GOOD LUCK BROTHER TECH / I HAVE THE SAME MACHINE AT HOME GOOD LUCK
Dec 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
78 people viewed this question
k24674
jasbo
jasbo
