Question about Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player
Sterio not workin
Hi my car sterio sparked at the back when i pushed it in place in my car just wonderin if it would be the fuse.
    New Friend:
  • 57 Answers
You may have fried it but check the fuses and find the exposed hot wire look for one thats black and melted and seel it up good
Posted on Jan 10, 2009
Turn signals not workin is not fuse 1989f350pu 460cu
There is also a turn signal flasher. Replace it. If that doesn't work, replace the signal/combo switch. It is the lever that you push up or down on the steering column.
May 03, 2016 | Cars & Trucks
Wonderin' which fuse in my 2006 chevy cobalt I'd need to change to get my cigarette lighters to work again?
there is a fuse block under the hood take off the top there marked on the back side of top its a 15 amp fuse
Jan 29, 2011 | 2006 Chevrolet Cobalt
My husband changed out my thermastate and now my radio doesnt work. The light are on but no sound.And my air conditioning it making a loud buzzing noise.
better git under that hood an inspec for anything pulled or not reconnected after service--also these days wen changing anything it can effect sensors if not done just rite--Im wonderin if the thermo is workin cause the cooling system is a major player
Aug 26, 2010 | 2005 Chevrolet Impala
Toyota corolla 1995 sterio fuse proublem
Trying replacing the radio fuse under your dash. You have blown the radio fuse, and I believe the dome light is on that fuse as well.
Feb 04, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Replace factory radio on 2002 yukon xl
all you gotta do is carfully pry the dash panel off (prying from the far left end is easiest) completely remove panel. then there are 2 clips that hold the factory sterio in place. push on the both clips while pulling the radio out. simply disconnect the wiring harness from the back of the radio. using an adapter avaliable at your local radio shop (scosche p/n gm02, mdarb and gm1483b) wiring harness, dash install kit, and antenna adapter. then simply match the colors on the new radio's harness to the adapter harness, crimping each connection with a "but plug". then simply follow the instructions included with the dash install kit to assemble the kit.connect the antenna adapter to radio, plug in all cables. test to see if everything works properly before the final install. install sterio into dash install kit, re installing kit where origional radio was. then simply put the panel back in its place by firmly pushing on it untill it snaps into place. then enjoy your new radio!
Dec 29, 2008 | 2002 GMC Yukon XL
Sony mhc-rg22
Your audio amplifier IC´s of your device are damaged
Aug 23, 2008 | Audio Players & Recorders
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Panasonic cd player not working when pressing the cd button on 98 jeep grand chrokee
check fuses
since you have a jeep thinking you go off road maybe hit couple bumps and jared something loose in the back of sterio system this is what i would check first
after that it might be that the sterio's face plate is not makeing connection right to base sterio
May 07, 2008 | Car Audio & Video
Neon in color
sounds like you might need a good cleaning or your tv has contaminated coolant in the picture tubes. or you just might need to adjust the screen control for the picture tubes.
Feb 20, 2008 | RCA P46924 46" Rear Projection Television
Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player Logo
78 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
