-   Have tried a 4gb card to replace the perfect 256mb card, but camera wont format for use. -   randall1
Mar 29, 2008
-   I need to update the firmware on my 710 to cover a 2G xd card but cannot find a mac osx compatible update. any thoughts?-   etam
Dec 09, 2007
-   The user manual indicate that when you insert the memory card make sure that the label is facing up.but no matter how I insert the card the camera can't see it.I don't know what to do?
Praktica Luxmedia 5203 Digital Camera-   cairoman
Only the Camera Manual will tell you the max capacity. They do have their limits and you could a be wasting your money or even find the camera does not accept it. Check the manual thoroughly and if still in doubt put the question to the Nikon Technical Support Team.
I am currently using a 1gb and a 2gb card with my camera. The only problem that I found with the 2gb card was that the camera won't format the card at 2gb. It will make it 1gb. Solution: don't format with the camera. Works great !!!
camera will not start.
The battery is fully charged, the light on the camera does not come on....
(More)
The battery is fully charged, the light on the camera does not come on. The CF card was full, but I removed it an deleted all the images. Tried the spare battery, and also attached to my computer. All to no avail.
Any ideas?
I have a Nikon Coolpix 4500 and it was working fine until a few days ago when i turned it on I...
(More)
I have a Nikon Coolpix 4500 and it was working fine until a few days ago when i turned it on I noticed a red square with what looks like a clock face flashing. I thought that I needed to reset the internal clock but when I tried to go into the menus all I can get to in the menus was the Picture Quality setting and nothing else no matter how many times I pressed the menu button... How can I get it back to normal operation... BTW I can still take pictures but only at one setting...
With my Nikon Coolpix I can copy pictures to my PC but can't copy pictures from my PC to the...
(More)
With my Nikon Coolpix I can copy pictures to my PC but can't copy pictures from my PC to the camera/card. I have an Sony Cybershot which I can copy pictures both directions - very convenient. What's different about Nikon?
With my Nikon 4500, right before I take a picture and after the flash has popped up, a small green...
(More)
With my Nikon 4500, right before I take a picture and after the flash has popped up, a small green rectangle often appears on the large square viewer, and it seems to have an envelope flap in darker green on the rectangle. Do you know what the bright green small rectangle means?
