Question about Brother Multi-Function Center MFC-5860CN All-In-One InkJet Printer
Ink cartridge I just installed a fresh ink cartridge in my fax/printer. The LCD still reads No Cartridge I am lost!
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
Near empty black is displayed even with new black cartridge
If you replaced an ink cartridge while Near Empty was displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes 2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand new one, please be sure to select 2.
WARNING
If ink gets in your eyes, irrigate them with water immediately and call a doctor if you are concerned.
If you wait until Ink Empty message is displayed on the LCD, the machine will automatically reset the ink dot counter.
If the Install message is on the display after you have installed ink cartridges, check that the ink cartridges are
installed properly.
Jan 01, 2011 | Brother IntelliFAX-2440c Plain Paper...
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
How to load new ink into printer Canon Pixma 620B ? Thank you!
Step 1.
Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    Not Receiving Faxes
    If it is a fresh ink and all carts have ink, you can unplug the machine and plug it back in while you hold the stop button for a few seconds after it powers up.That usually clears the error.
    Nov 04, 2009 | Brother IntelliFax-1860C All-In-One InkJet...
    I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
    My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
    Lou
    Oct 17, 2009 | Brother MFC-685cw InkJet Printer
    We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
    it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
    -open cartridge door and remove the cartridge
    -unplug the power cord at the back of printer
    -after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
    -Open the cartridge door and insert the cartridge
    -close the access door
    -if the error is cleared, try faxing again.
    I hope this helps.
    Regards,
    Mar 02, 2009 | HP 640 Inkjet Fax Machine
    Intellifax 1860c no cartridge or replace ink keeps showing up
    I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
    Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
    Brother Multi-Function Center  MFC-5860CN All-In-One InkJet Printer Logo
    62 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
