Question about Cuisinart DLC-5 Food Processor
Cuisinart 7 cup food processor wont' start
I have put everything on correctly and it won't start
  • Anonymous Mar 16, 2014
    i have tried everything but i cant get the food processor to turn on i am thinking i may have a faulty one.
  • 8,596 Answers
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Posted on Jan 15, 2009
Is the Cuisinart DLC 7 Super Pro Manual available to download?
Manuals can be found here:
Food Processors Product Manuals Cuisinart com
You'll have to look around at the options and pick one that looks like the one you have.
If you have an older one, the handle for the bowl generally goes in front, and check the base to see if the button that gets pushed down when the top is in locked position is in the front or the back... and try to match that. The DLC-10s has it in the front (7 cup machine), but many of the larger machines have it in the back. The feed tube matches up with the button when you put the lid on. If you put the lid on with the feed tube 180 degrees off, you can break the lid/bowl getting them apart again.
Getting this right is the most important thing... otherwise they just kind of work. The link for the 7-cup Pro Classic Food Processor (DLC-10s) has really good technique information with color photos. It's worth grabbing regardless of the machine you have.
http://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Other manuals have other recipes... so you might want to download more than one manual.
Jul 03, 2014 | Cuisinart DLC-5 Food Processor
Need instructions for cuisenart 7 cup processor
To to:
and look for a machine that is from the same generation as yours (check the shape of the base).
For your 7-cup machine, a good manual might be the following:
Pro Classic Food Processor (DLC-10S)
Manual
Apr 26, 2014 | Cuisinart Food Processors
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
My cuisinart DLC-1ss will not start once plugged in.
The bowl must be locked in the correct position for the unit to turn on.
Remove the bowl, place on unit and rotate into place.
Oct 04, 2010 | Cuisinart DLC-1SS Mini Prep 2.63 Cups Food...
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Dec 07, 2008 | Cuisinart DLC-5 Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
Appears to be locked but won't turn on
ah! well my mother just tried using her DLC-10S 7 cup food processor and she also encountered the same problem. It worked perfectly fine when she first used it around Christmas time but not anymore.
After almost smacking the hell out of it we discovered that there is a plastic tab on the lid towards the handle side. This plastic tab actually pushes a lever through the cup and into the base of the food processor.
New Bee actually mentions this above. The problem is that the flimsy plastic tab in the handle isn't stiff enough to push the lever down anymore. I'm amazed it worked the first time.
This is very much a design flaw by Cuisinart as there's no way this plastic tab would ever last.
Now there is a small opening in the case right above the plastic tab. To get our food processor going we just pushed a chopstick down on the tab and held it in place while the food processor runs.
This is very much a temporary solution until we get a new food processor, obviously a different model.
Nov 22, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-5 Food Processor Logo
3,886 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
