Question about Hyundai L90D+ 19" LCD Monitor
We have a Hyundai monitor that will not show the picture
  • 32 Answers
You need to verify whether it is your video source (ie: computer) or the actual monitor. To do so, put the monitor on another computer or try another monitor on your computer. That is the easiest to tell which one it is. If your monitor works on another computer, it's your computer, if not it's your computer and vice-versa.
Posted on Jan 06, 2009
Where is the cam sensor located on the 2001 Hyundai Santa Fe
http://www.youtube.com/watch?v=5gwta1NvtsQ
This may help
Feb 28, 2013 | 2001 Hyundai Santa Fe
Screen shows correct image then goes black. if monitor switched off then on proper screen shows for a second then black again.
problem related to lcd lamp supply
just replace the power supply(called inverter board) connected to the lcd panel lamp
Jan 21, 2011 | Hyundai ImageQuest Q15 15.1" Flat Panel...
When it turns on the picture shows for a second then turns off
hi solution of this problem u can change cfl of lcd screen
Jan 13, 2011 | Hyundai L91A 19" LCD Monitor
Hyundai X91D power light flashing green with no picture
Try it on another PC alos check the VGA cable first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Hyundai Electronics X91D (Black) Monitor
First place to look will be capacitors in the power supply section, look for caps with bulging tops, the problem can also be in the inverter circuits due to shorts circuits. You will need to open it up and inspect the inside, post back what you see so we can guide you further, see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | Hyundai Electronics X91D (Black) Monitor
My hyundai n91s is showing bright white light but their is no computer image on the LCD
My Hyundai n92s is showing bright white light but there is no computer image on the LCD
Jan 17, 2010 | Hyundai Electronics ImageQuest N91S 19"...
Backlight of Hyundai X93W dead
The fault is most likely a faulty inverter board.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site :-
www.lcdparts.net
Jan 09, 2010 | Hyundai Electronics Hyundai LCD 19"...
Power on Green Light Blinks but no picture. Will not turn on. Hyundai Image Quest L705
bwpvemail, The units "switch-mode-power-supply" may be in shutdown mode. A tech will need to evaluate. Check to see if Hyundai has a refurbished swapout+cash program?? It's that or trade in for new wide screen, so the tech in the store "back-room" can possibly put $8 in new filter capacitors in your unit and with a little luck will have a 17" L70s for 1-2 more years use. 12fixlouie
Dec 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
My hyundai monitor
There's a certain combination of keys you must press to restore your monitor to its factory settings (the original settings of the monitor ). The most common way is to press the up and down button together (normally beside the function/ menu button). Another way to lighten/brighten up the display is to raise the brightness settings of the monitor or by changing the contrast settings. This method enables you to customize the display of the monitor to suit your needs. If you still have the manual of the monitor, you can find instructions on how to change the settings of your monitor.
Dec 30, 2007 | Hyundai ImageQuest ImageQuest V773 17" CRT...
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
172 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
