Question about Lexmark X75 All-In-One InkJet Printer
Everything seems to be in order. then I click on print and the first line prints and then the printer cartridges seem to slide to the side and the printer stops, with the power light and the status light blinking. when I open the printer to examine the cartridges, instead of being slightly to the left of center, they are all the way to the left. Can U help?
  • 685 Answers
Unplug it for a couple minuets and plug it back in and then try a test page.this will reset the printer when u unplug it
Posted on Jan 08, 2009
I cannot change the cartridges as yhe holder seems to be stuck
Welcome to FixYa!
Note: When removing and inserting back the print cartridges, you need to use a small amount of force because of its safety locks. Just be careful not use excessive force, it might damage your printer.
If your printer has Two Cartridge System with no latches, here's a proper way to remove and insert the print cartridge. Please refer to the image below.
1. Press down the tip of the print cartridge and pull it away. You will hear a "click/tick" sound while pressing it downwards.
2. Make sure to remove the protective cover of the print cartridge.
3. Slide in the new print cartridge in its holder.
4. Lock it by doing the figure #4 in the picture below. You will hear a "click/tick" sound which indicates that it is locked.
If your printer has Two Cartridge Systems with latches, here's how to do it.
1. Pull up the latch. You will hear a "click/tick" sound.
2. Pull away the print cartridge.
3. Make sure to remove the protective cover of the print cartridge.
4. Slide in the new print cartridge.
5. Close the latch. You will hear a "click/tick" sound.
Thank you for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP DeskJet 940c InkJet Printer
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My printer is connected, nut doesnt seem to work
Check whether the printer is in offline. Double click the printer icon in the bottom right of the screen (near time). Or double click your printer in the printers and faxes. Your printer job menu will open. Select printer and check whether use printer offline is ticked. If so, remove it. The another problem is your usb port number may be changed. check it in printer properties.
Jan 08, 2010 | Office Equipment & Supplies
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Doesn't see print cartridge
there are some lock for cartridge in printer right side cover may need to be adjusted
check if its get lock when toner is slide in side printer
spring at RHS for lock need to be check
Nov 07, 2009 | HP LaserJet 3050 All-In-One Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
My printer will not print. The cartriges seem to
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Mar 12, 2009 | Lexmark Inkjet Z517 Photo Printer
Printing 1 1/2" down right side of paper
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Nov 25, 2008 | Canon PC-980 Color Copier
Canon mp30s cartridge jammed
Since making my query post my husband seems to have solved the problem. I first tried the solution offered here for another printer model (remove then replace actual print head unit with the cartridges intact) but that didn't help. So my husband put a small amount of WD40 (also known as CRC) on the slide bar that the print head moves along. That seems to have freed everything up.
Oct 10, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Lexmark X75 All-In-One InkJet Printer Logo
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
