Question about Coby TVDVD1350 13 in. TV/DVD Combo
Need v-chip code Coby TVDVD1350 13 in
I need the V-Chip code to restrict my child from watching the wrong programs
  • Mirene21 Mar 13, 2008
    I need v-chip code Coby TVDVD1350 13 in problem, please notify me of some solution.
    Thanks
Does anyone know the default pass code set by the manufacturer to unlock the parental settings on a Coby DVD R1300? Thanks!
Persistent aren't we Jessica
Parental Lock - Coby. Page 40
Theinitialpasswordis"0000".Thepasswordmay bechangedintheParentalControlmenu.DoNOT forgetthepassword. Menu Item V-Chip Setting RRT Setting Page 0 Set the V-chip options. You can set the following program types to "View" or "Block". • Movie Ratings • USA TV Content Ratings • Canada English Ratings • Canada French Ratings Display the Region Rating Table menu. Description Coby Electronics Corporation
http://www.manualslib.com/manual/29649/Coby-Coby-Tv-Dvd2090.html#
unlocking
http://www.dvddemystifiziert.de/codefree_en/coby.html
Here a few assorted codes
http://www.tvblanket.com/how-to-unlock-your-tv-parental-control-password/
Or ask direct
Coby Electronics
Jul 05, 2016 | Coby Televison & Video
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Jan 21, 2010 | Durabrand DU1301 TV
V chip on and remote is gone
no. you are a child that wants to watch bad shows huh? well you are on the internet so do it here.
by the way, the "v chip" is just a basic programming in the computer so you cant actually take a chip out.
Sep 08, 2009 | Emerson EWC20D3 20 in. TV/DVD Combo
What does v chip mean? My TV is working and on the screen it says "V chip has been activated".
v chip is a generic word for the chip in your tv that controls what you can watch by the ratings. This is used by parents to restrict what programs thier children can watch. You can access this settings in the menu of your tv.
Sep 07, 2009 | Office Equipment & Supplies
V-chip or parental control
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Orion 13 inch television and the v chip
* Turn the volume down to 0
* Change to a blocked channel (where it asks for V-Chip password)
* On the TV (not from the remote) hold the volume down button
* (While holding volume on TV) hold the '0' key on the remote for between 2-10 seconds...
* The screen should unlock, and you should have no V-Chip restrictions.
Nov 01, 2007 | Televison & Video
Coby TVDVD1350 13 in. TV/DVD Combo Logo
20 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
