Question about HP Scanjet 4850
Blue background everytime I scan an item there is an annoying blue background any help out there
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Why when I select color copy on HP Deskjet 3050 J610, it prints with a blue background?
The issue is from the glass on the copier, it would be better if you clean it very well or possible change.
Aug 20, 2014 | HP Deskjet 3050 All-in-One J610A Printer :...
Acer h233h monitor has blue tint all over screen
It's any one of these issues in decreasing importance video cable, video card, monitor. Make sure the video cable is plugged into the monitor and computer firmly first. After that, start replacing until you hit the culprit. You should be able to take any one of these items back to the store if it doesn't fix it.
Oct 22, 2012 | Acer H233H BMID 23 Widescreen HD Flat...
PC GAME LAG... PLEASE HELP!
You may want to try the following.
Disable windows search, it may be trying to index files in the background and HD access may cause annoying pauses while playing games.
Check that your anti virus is not running an automatic or scheduled scan when you are playing, this will deffinatley cause jittering.
Are you uning an integrated graphics chipset ? If you are you may want to upgrade to a discrete card AMD 3850 are very cheap and i use mine for Mirrors Edge and Battleforge and it runs great.
Update your graphics card drivers.
Use add remove programs and get rid of everthing you dont use. The apps may have processes running when you are not even using them. iTunes and Quicktime are really bad in this respect.
It you are playing online ensure that you are not running file sharing apps in the background. Also if you share internet access with anyone else check they are not doing the same. File sharing is a nightmare for online playing performance.
Close everything you are not using including IE and Firefox. Flash ads in web browsers can use a suprising amount of CPU time.
Hope this Helps
Lee
Dec 05, 2009 | Office Equipment & Supplies
Disabling auto music everytime i log onto internet
This can be a possible virus/malware which gets activated when you starts internet. Try to install a good Anti-virus with malware protection and run a scan. This will help you getting rid of the annoying music.
Feb 22, 2009 | Toshiba Satellite M35X-S149 PC Notebook
DVD Player Stuck In Progressive Scan Mode
A simple solution that works with electronic items many times, so give it a try. Turn Off your player, un-plug the electrical supply, wait about 2 minutes then re-connect the electricity and turn on the player. Many times this will force the machine to reset itself. This technique can be used for ALL electroinc devices.
Jan 16, 2008 | Zenith XBV243 DVD Player/VCR
All scanned documents have blue background.
You have to take the machine to service partner who can be found on the brother homepage of your country.(www.brother.com)
The scanner needs calibration which can only be done by service personel.
Dec 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Scanning barcodes with colored background
unfortunately it appears that you do not have sufficient Contrast for your barcodes, this will make scanning them difficult, that with the added issues of wear & fading makes the use of barcoded passcards difficult. it's probably better to use RFID or Magstripe cards for this application
Sep 05, 2007 | HHP Imageteam 3800 Handheld
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
HP Scanjet 4850 Logo
285 people viewed this question
Seeker5211
Seeker5211
