Question about RCA P50830BL 50" Rear Projection Television
Picture No Sound
I was watching tv one day and the next day i had no sound. picture but no sound, any advise would be great.
  • 3130 Answers
SOURCE: high pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Posted on Aug 26, 2006
  • 375 Answers
SOURCE: beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Posted on Aug 22, 2007
  • 5138 Answers
SOURCE: tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: Heard a loud
Just had the same problem.
Unplugged the set from 110V.
Replaced the bulb, following instructions in owners manual.
Plugged the set back in and it worked 100%.
Bought the bulb from Tristate Module Inc. for $113- including shipping.
User manual can be found
click on TV's,
click support,
click GO in Downloads, enter your screen size and model number.
click on User Guide & Warranty
A 96 page pdf user guide will display.
**** Bartlett
Posted on Apr 17, 2009
  • 19396 Answers
SOURCE: A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 3866 Answers
SOURCE: tv has sound ,no picture,power light comes on
Tihs would be the power supply unit gone bad.
1. Check power supply fuse if the fuse is blow so are the caps do not try to replace the fuse you will smoke this thing.
2. upon inspection you can remove the power supply unit and buy a new one. There about $150 bucks aftermarket for this unit. So I would be looking for other RCA's with this same series and pull some psu's to save money.
I hope this helps you find a solution for your TV these are nice to have and worth the repair.
Posted on May 21, 2009
0 characters
1 Points
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
No Picture, but I have sound!
Your color tube has probably went out that is why you have sound but no picture, you will have to call a tv repair place or where you bought it from to get an estimate on having it repaired
Jul 22, 2009 | Projection Televisions
Mitsu model #ws-55905 Started losing picture while watching a DVD. The next day it worked fine. Now it lost the picture and sound completly. I have no response at power on, only the green power indicator....
actually something on the main board was getting overheated before due to that it was loosing the picture.and now that component is got totally overheated and blowned/burned its quite necessary to replace that faulty component from the board by checking it with a its advisable that you do not turn on your tv to avoid further damages till it gets repaired.
Feb 20, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Hitachi 60vf820 ultravision
Good Day, bgblueeyess;
Your somebody is wrong; replace the LAMP.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
RCA P46130 no picture
i tried unplugging mine when the picture went out. i left it unplugged for about 10 to 15 minutes. still no picture
Jan 10, 2008 | Philips 50P8341 50" Rear Projection...
Swaping pip images
you need to check your cables. what brand of tv are you using?
Nov 28, 2007 | Sony KP-53V90 53" Rear Projection...
Projection Televisions Logo
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
