Question about NMB Technologies Panaflo/NMB-MAT 120x38mm low speed fan FBA12G12L1A Fan Kit
Replacement for NMB-MAT FBA06A12L
I am trying to replace a NMB-MAT cooling fan. The markings on it are 6G10A73 -4PX Model FBA06A12L DC 12V 0.13A. I can't find this exact fan. Can you tell me what replaces it?
3 Suggested Answers
  • 34 Answers
SOURCE: Fan has gone out on my NMB Tech power supply
Hi. If you know how to fix it just do it. You don't have to replace fan it just must work.
Posted on Oct 19, 2009
byteguy
  • 2229 Answers
SOURCE: CHIP COOLING FAN FAILED
These fans fail on an alarmingly regular basis.
In the past, if I can't find a fan, I simply remove the fan and leave the housing attached to the chip. It acts like a heat sink. Sometimes I think that the fans are just there to look neat!
You "may" be able to find a small heat sink that will do the job without a fan. That is another thing I have done. By searching your local supplier for just a heat sink, you might have better luck.
Posted on Mar 29, 2010
Jazz831
  • 39 Answers
try on ebay
Posted on May 18, 2010
Noisy fans on a desk-top pc Model Acer Veriton 1000. Besides replacement for new fans, can brushless fans be serviced or lubricated?
The Veriton 1000 I have has 50mm fans (length and width). 80mm are the wrong size. They are 15mm thick, 12V, 0.2A. For some reason, these seem to be more expensive than many other fans.
Jul 13, 2012 | Computers & Internet
The fans are not working. Would like to have part number to the fans.
The fan replacement is not hard, but it is fiddly.
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the cover and tapping the top of the cover to release the top tabs. Undo the screws on the metal plate which hold the battery in place. Take off the UPS outer metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the location of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan manufacturer's label should face the back of the UPS.
This solution is for a PW9120-1500. I assume your UPS is PW9120-3000 or larger. Check the model of the existing fans.
Feb 24, 2011 | Powerware 9120 UPS System
Need to replace the fan on a powerware 9120T 1500VA
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the and tapping the top of the cover to release the top tabs. Take off the metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the locaton of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan maufacturer's label should face the back of the UPS.
Jan 20, 2011 | Powerware 9120 UPS System
My Panasonic is Model# SA-ht650. The fan does not come on to cool the unit down. I took the fan out and tested it and it does work with 12 Volts DC @ 1.5 amps. Any suggestions.
For others, the fan on this model only runs with the volume turned way up, to test it unhook the speakers and play something like the radio with the volume set to 0dB, the fan should run.
Dec 23, 2010 | Panasonic SC-HT650 System
I need a 2x2 brushless fan model # rdm5015s dc 12 volt. where do i find one please?
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
May 10, 2010 | Sanyo /San Ace DC 12v Brushless FAN Assy
Bad blower (fan) in Astec RS-PSU-450-AC1N
If you cannot find a exact replacement, don't worry, use a fixed speed fan, you only want to keep things cool, you care what speed it runs at as long as it does its job, and it is easier than replacing the bearings
Nov 28, 2008 | Computers & Internet
NMB Technologies Panaflo/NMB-MAT 120x38mm low speed fan FBA12G12L1A Fan Kit Logo
235 people viewed this question
Top NMB Technologies Computers & Internet Experts
David Payne
David Payne
Are you a NMB Technologies Computer and Internet Expert? Answer questions, earn points and help others
