Question about RCA DRC8295 DVD Recorder/VCR Combo
How do i get digital output - RCA DRC8295 DVD Recorder/VCR Combo
  • 492 Answers
Digital output is usually provided 1 of two ways.  The first is call coax.  This is typically an rca connector that is color coded black or orange.  You can use just about any rca cable to connect it to the same color connector on the back of your surround sound receiver.
The other is called and optical connector.  Refer to your manual to see which one you have.
Posted on Jan 06, 2009
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
I've an LCD with built in digital tuner, how do i
No the Tuner doesn't have an Output, so one cannot get a signal OUT of the Tuner, UNLESS there is a Tuner Out, A Monitor, OUT. Then you cannot get any signal to feed into the device you wish to record with. The signal MUST go to a TUNER first, then the OUTPUT may be fed to anything else. As said IF the Device with the Tuner HAS a way of outputting Video & Audio, then you can take that signal and record it, otherwise you cannot.
Mar 30, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
Cannot get digital output
Digital output is for the reproduction of 5.1 or higher surround sound.  Though it will support 2.0 audio it is not meant to be hooked up to a tv, but meant to be hooked up to a surround sound reproduction device.
Jan 06, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Connecting for surround on the PD-DVR100
HOWDY-ARE YOU FAMILIAR WITH "HDMI"--DESCRIBE THE CONNECTOR YOU REFER TO--YOU ARE STILL TALKING ABOUT THE PD-DVR100--RIGHt? / RSVP------SARGE
Jul 27, 2008 | Protron PD-DVR100 DVD Recorder
Video Connections
These are all the connectors on the back. The "1 x component video output" indicates that you can use the "3 color video cord" you have, better known as Component Video Cable.
Connector Type: 1 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video output ( RCA phono x 3 ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear ¦ 1 x digital audio output (coaxial) ( RCA phono ) - rear ¦ 1 x digital audio output (optical) ( TOSLINK ) - rear ¦ 1 x network ( RJ-45 ) - rear ¦ 2 x USB - front
May 16, 2008 | Toshiba HD-D1 DVD Player
Dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
Apr 11, 2008 | Philips DVP5960
Changing from RF to digital on Panasonic DMR-ES20DEB
Audio? Video? input? output? Short questions are nice but vital details are helpful....
Lets assume your talking Audio output since those are the only digital settings you can change, but first a little bcakground.
RF would refer only to you video input via the tuner if thats what your referring to it should simply be a matter of changing the input (channel up/down or input up/down).
Your audio output can be changed from analog to digital and vise versa and can be chaged from the Menu(hit Menu when no DVD playing) settings under audio.
Mar 24, 2008 | Panasonic DMRES20D DVD Recorder
No sound
The Philips DVP5982 has an odd menu setup for the HDMI sound.
If you get sound from the analog outputs from the unit, but no sound when you use the HDMI output, use this procedure to see if you can restore it:
On the remote control, press Setup.
- Right cursor to the Audio Setup Page
- Go down to Digital Audio Setup
-Right cursor, to get to the screen that shows
Digital Output
LPCM Output
HDMI Audio Setup
Try to go up to the Digital Output setting- if you can't , and instead it shows only HDMI Audio Setup with the "On" highlighted in blue, this is the quirk:
Go into the HDMI Audio Setup, and select "Off", and press Enter, so it's highlighted in blue.
Now it should let you go into the Digital Output menu selection, where you may find it to be on the "Off" setting.
Select "All", and then you can go back to the HDMI Audio Setup and set it to On again, and it should now output sound from the HDMI again.
For some reason, they decided to lock out the Digital Output settings menu when the HDMI Audio is On- go figure.
So you need to turn off the HDMI sound before you turn the sound on.. ;)
Jan 12, 2008 | Philips DVP5982
RCA DRC8295 DVD Recorder/VCR Combo Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
