Question about Microsoft Visual Basic 6.0 for PC
Visual basics related
Tell me the coding to be done to check that a number is prime or not
as soon as possible.
  • 11 Answers
My overdrive doesn't work in my 1999 s10 pickup
The following are the general instructions on the start of diagnosing any electronically controlled engine or transmission problem.
The engine and the automatic transmission (transmission control is only for automatics, engine is still computer controlled no matter the transmission type) in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems. Also engine mechanical problems ca cause many drive-ability related problem such as rough idle and other symptoms
Oct 22, 2012 | 1999 Chevrolet S-10 Pickup
WHAT IS THE CODE P0341
This P0341 code basically means that the powertrain control module (PCM) detected a problem with the camshaft signal. The camshaft position sensor (CPS) sends a specific signal to the PCM for Top Dead Center on the compression stroke as well as signals indicating the position of the cam sensor. This is accomplished through a reluctor wheel attached to the camshaft that passes by the cam sensor. Any time that the signal to the PCM is inconsistent with what the signal should be, this code is set. NOTE: this code can also be set by extended cranking periods.
FB.init("dd7d9e9681341cde77587bc6a2029f6f"); OBD-Codes.com on Facebook Symptoms The car will likely run with this code set, as it is often intermittent and also because the PCM can often operate the vehicle in "limp-in/limp-home" mode even with a cam sensor signal problem. There may be no noticeable symptoms other than:
  • Poor fuel economy (if engine runs)
  • Possible no start condition
Causes A code P0341 may mean that one or more of the following has happened:
  • Cam sensor wiring routed too close to spark plug wiring (causing interference)
  • Poor wiring connection at cam sensor
  • Poor wiring connection at PCM
  • Bad cam sensor
  • Damaged reluctor wheel
Possible Solutions Often relacing the sensor fixes this code, but not necessarily. Therefore it's important to check the following:
  • Check that the wiring isn't routed too close to any secondary ignition components (coil, spark plug wires, etc.)
  • Visually inspect the wiring at the sensor for any burn marks, discoloration indicative of melting or chafing
  • Visually inspect the cam sensor for damage
  • Visually inspect the reluctor wheel through the cam sensor port (if possible) for any missing teeth or any damage
  • If reluctor isn't visible from outside the engine, visual test can only be done by removing cam shaft or intake manifold (depending on engine design)
  • If all checks out okay, then replace the sensor.
Related Camshaft Trouble Codes: P0340
Mar 07, 2012 | 1996 Saturn SL
1998 saturn sc2 po341
P0341 - Camshaft Position Sensor Circuit Range/Performance
Symptoms: The car will likely run with this code set, as it is often intermittent and also because the PCM can often operate the vehicle in "limp-in/limp-home" mode even with a cam sensor signal problem. There may be no noticeable symptoms other than:
* Poor fuel economy (if engine runs)
* Possible no start condition
Causes: A code P0341 may mean that one or more of the following has happened:
* Cam sensor wiring routed too close to spark plug wiring (causing interference)
* Poor wiring connection at cam sensor
* Poor wiring connection at PCM
* Bad cam sensor
* Damaged reluctor wheel
Possible Solutions: Often relacing the sensor fixes this code, but not necessarily. Therefore it's important to check the following:
* Check that the wiring isn't routed too close to any secondary ignition components (coil, spark plug wires, etc.)
* Visually inspect the wiring at the sensor for any burn marks, discoloration indicative of melting or chafing
* Visually inspect the cam sensor for damage
* Visually inspect the reluctor wheel through the cam sensor port (if possible) for any missing teeth or any damage
* If reluctor isn't visible from outside the engine, visual test can only be done by removing cam shaft or intake manifold (depending on engine design)
* If all checks out okay, then replace the sensor.
Hope helps (remember to rate this answer).
Jan 03, 2011 | Saturn SC2 Cars & Trucks
PO 341 code on 2002 chevy impala
Here is a possible solution to the problem;
Be cool!!!!
Aug 02, 2010 | 2002 Chevrolet Impala
I want to map ip to hostname in visual basic 6.0 code can anyone know any library class which will resolve the DNS names in VB code pls send me mail as soon as possible
This is handled by the "hosts" file on a machine. That file lives in the folder: C:\Windows\System32\drivers\etc
This file (named "hosts") is there for this purpose. You can modify it as you would any text file using VB6. Just be sure to maintin the file's contents format.
Apr 15, 2009 | Microsoft Mlf Visual Studio Enterprise...
I have a visual basic program in which i have to display the record from access table by using connection of adodc.and then select record from datagrid will display in another form. plz reply as soon as...
hi,  you may visit this site www.kidwaresoftware.com/ and download all free visual basic source codes with tutorials..  One of the source code will solve your problem.    However their paid Visual basic source codes will most powerful.    As I am total deaf and no source to communicate others... I want to share the  payment source codes with tutorials from  www.kidwaresoftware.com/.  Are you ready... If you download the  source codes with tutorials (only Fee for it) I will share with you.    esakkisivaganesh@yahoo.co.in
Apr 08, 2009 | Microsoft Visual Basic Enterprise Edition...
Can i get source code for calculating arithmetic operations of vb
just take a look to this site:
http://www.codeproject.com/
you'll get all your answers about VB and totally .NET there by a simple search
enjoy it!
Feb 19, 2009 | Microsoft Visual Basic 6.0 (361-00686) for...
Hi........
I wrote this as a vbscript. It's Visual Basic code in windows script. If you have XP, just copy the text into notepad and save it as "vowel.vbs". Now double click the newly created script file.
' vowel.vbs
' This VBScript is used to count the vowels and consonants in a string.
' Designed and Tested on Windows XP Pro SP2
' Version 1.0.0 - 02.20.2008
' This code may be freely distributed or modified.
Option Explicit
Dim str
Dim vowels
Dim consonants
Dim i
vowels = 0
consonants = 0
str = "hello"
for i = 1 to len(str)
select case mid(str,i,1)
case "a"
vowels = vowels + 1
case "e"
vowels = vowels + 1
case "i"
vowels = vowels + 1
case "o"
vowels = vowels + 1
case "u"
vowels = vowels + 1
case else
consonants = consonants + 1
end select
next
msgbox "Vowels = " & vowels
msgbox "Consonants = " & consonants
'End of script.
Feb 21, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Microsoft Visual Basic 6.0 for PC Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
