Question about Emerson EWD2202 DVD Player/VCR
Unit powering off unable to stay on
Emerson ewd2202- unit turns on and right back off. open cd tray unit's on closes on auto (CD or not) and powers back off
  • haha4000 Nov 21, 2007
    I have a Emerson EWD2202 Dual DVD/VCR and mine as well will power on for about a minute and then shut itself off. The indicator on the front panel that says cst in is flashing green.
  • Grobb Dec 22, 2007
    Unit powering off unable to stay on problem,
Mine did the same thing. Try this turn the power on with the remote, hit the record button and the tape should come out. This means that you need to record something.
Chet
Posted on Nov 25, 2007
SL-PD8 cd tray is opening and closing, nonstop.
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Jul 26, 2009 | Technics SL-PD8 5-Disc CD Changer
Cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
Mar 31, 2009 | Sony CDP-C265 CD Player
Replacing the DVD part of the Emerson EWD2202
You can buy the replaysment parts from Funai web site
Emerson is a one of tradmarks of Funai
Just follow this link
Good Luck
http://www.funai-corp.com/support/faq.aspx
Feb 03, 2009 | Emerson EWD2202 DVD Player/VCR
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Oct 30, 2007 | HHB CDR850 CD Recorder
Emerson MS9700 CD Shelf System - CD Tray won't open
Ironically, I am here searching for information about this kind of problem too, except I don't have cd's stuck in the unit. This one has done the no power on trick as well as some other pretty stupid stuff. I know this is an old post so if you haven't got it working yet or gotten the cd's out, the only way I know of to do this would be to remove the screws on the outside of the unit and remove the case. Once you do this you can get the cd's out, then.......... TRASH THE THING!
Aug 26, 2007 | Emerson MS9700 CD Shelf System
CD tray opens and won't stay closed for burning
Sounds like an issue with the contact behind the button on the drive. How old is the drive? Replacements are cheap these days.
Sep 04, 2006 | HP (dw381a) CD-RW/DVD-ROM (Combo) Burner
Emerson EWC13D4
The door switch contacts located under gear on side of unit needs adjusting or cleaned. these contacts turn on cd motors. cd will not work until contacts are working proper.
Feb 01, 2006 | Emerson EWC13D4 13 in. TV/DVD Combo
Emerson EWD2202 DVD Player/VCR Logo
150 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
