Poor sound quality from Hi-Fi
After a party on NYE i have noticed significantly reduced quality in the sound of my dennon PMA250 III Hi-Fi. I think this coiuld be due to overheating. Is there any way to tell/get this repaire?dThanks in advanceLuke
    President:
  • 624 Answers
It may have a ffew components in it that have failed, the only way to know is to have it checked by a technician. Call the nearest electronics service center to your home and ask them if they repair this brand. If they do not, you can ask them if they know who does in your area. Tell me where you are at and I may be able to find one for you. It does need troubleshooting to determain the cause of your problem.
Posted on Feb 06, 2009
My lexmark prevail pro707 does not compress scanned files, these files become too large to email, how do I set it to compress scanned files please?
On my 901, I can reduce the size of the PDF file by changing the "quality" setting in the scan mode. More specifically, reducing the DPI that it scans at. I also noticed that scanning a document to a wireless network computer, and then scanning the same thing again directly to a flash drive plugged into the printer, results in significant variations of the file size. Perhaps trying different combinations of these things will help you with your problem. Good Luck.
May 29, 2014 | Lexmark Prevail Pro705 Wireless All-In-One...
I have a HP LaserJet 3053 printer that has been making a clunking sound everytime I print something out. Recently the toner has been smearing on some of the copies, also. Any advice will be helpful.
sounds like your toner cartridge is faulty. Has it been clunking since you replaced it - if so have you bought a 3rd party toner - some can be really poor quality. id reccomend getting a hp cartridge or a decent 3rd party
Oct 22, 2013 | HP LaserJet Office Equipment & Supplies
Poor sound quality
IP phones compress analog data to avoid excess bandwidth. When calls are placed long distances this becomes really noticeable.
Sep 27, 2013 | Mitel 5312 IP Phone
Hi I am having a LG VCR GC980W 6 heads HiFi model. There is a bad picture and sound in some cassetes while playing while in another video the same cassetes works fine. I wonder whether it can be belt...
This is adirect drive type and the poor picture quality has nothing to do with the belt.
The fault can be due to
1. fault head- since this is a Hi-Fi type , it is 6 head type. try cleaning the head to confirm, use a clean cassette.
2. Problems in the head amplifier circuit.
3. Check the RF connection to TV.
4. Clean the audio head and use a ordinary cassette to confirm the sound. Also try with a Hi Fi cassette.
If not the head is a suspect.
Sep 13, 2011 | Televison & Video
Video quality suddenly reduced
That means you have mistakenly changed it from Standared Mode  to Compact Mode ..
  1. Standared Mode: Hi Quality with the (Video Camera Symbol)
  2. Compact Mode: Low Quality with the (Vidoe Camera + Envelope Letter Symbol)
The Solution: Rotate the Wheel to toggle between these 2 Modes
Mar 22, 2009 | Canon PowerShot SX100 IS Digital Camera
GETTING BETTER SOUND QUALITY
An equaliser is, put simply, a more complex tone control, giving you the ability to cut or boost more specific frequencies than a tone knob, or bass & treble controls.
It comes in handy for tweaking the sound from your hi-fi to just the way you like it. But beware, as it can make your hi-fi produce sounds that are so bass or treble heavy, that you can damage your speakers if you're not careful.
Adding another compnent into the chain (like a graphic EQ) can add a little background noise but this Technics EQ is a pretty quiet one & you probably won't notice the noise apart from when there's no music playing & you've got the amp turned up high.
Jan 10, 2008 | Technics SH-GE70 Home Equalizer
POOR SOUND QUALITY
get some woofers and amplifiers attached to it.they wont cost u much and u will then have an excellent sound.....
Dec 01, 2007 | Audio Players & Recorders
Defrag causing poor quality sound
uninstall and reinstall your sound driver from the mother board CD
Jun 26, 2007 | Compaq Presario EZ2605 (A89712-007) PC...
Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Mar 08, 2006 | Zenith VRA421 VHS VCR
 Grubhead
Grubhead
