Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Received new printer need to mail back old printer.
UPS wants to charge $10.00 to pick up printer.
  • 45 Answers
Send the bill to Kodak!
Posted on Jan 13, 2009
Where and how do i put batteries in epiphone les paul standard
If your pick-ups are active pick-ups, then yes they require a
battery(s). Typically that guitar comes stock with passive (non-active) pick-ups and do not requuire any batteries. How ever if they are needed, you need to remove the plate cover directly behind the volume knobs. (located on the back of the guitar). open that up, If it requires a battery, there will be an old one in there more (than likely)
and that should tell you everything you need to know. probasbly a 9volt. good luck
Dec 25, 2014 | Epiphone Music
27.5 volt charging voltage
No, that right. The batteries are wires in series so the voltage is 24v and they need a little high input than that to charge correctly.
Jul 25, 2012 | APC Back-UPS Pro 1400 UPS System
Does not power on but indicates charging
There could a couple of problems that would be the reason that the UPS is not able to power your equipment.
1. You have exceeded the output limits of the UPS. If the power demand from all the devices exceed the UPS' capacity. The model that you indicate should be able to power a total of 1000 watt load for about a few minutes. If should be able to power your computer, monitor, modems/routers easily, but if you have a laser printer attached, it will not be able to sustain the demands of the printer. Try removing any heavy loads like printers and see if this will work.
2. The battery in the UPS needs to be replaced. The battery in a UPS is only good for a few years. After a while it needs to be replaced because after a while it is not able to supply the needs of the UPS. If the battery is more than 2-3 years old it should be replaced.
Hope this help you.
Jul 02, 2010 | APC Smart-UPS 1000VA UPS System
Uninterruptible Power Supply problems. My uninterruptible power supply (UPS) is not backing up during a utility power outage.
First, we do need to full charge it. Then see what's being able to pick up a load of this Ups power or not? If not then it means something is wrong with this Ups. Please put this change.
Jun 30, 2010 | Powerware 9120 UPS System
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
Battery is not loading
dear marc 68
i think u have problem in ur battery.....if battery is in warenty.replace it emidately...
try a new battery......
i m 100% sure u r problem will be solved man..
dont forget to vote for me...
dont forget to tell me u r problem solved or not
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
Oct 11, 2007 | Belkin Home Office UPS System
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
