Question about HP Photosmart D7260 Printer
My HP Photosmart suddenly started blobbing out ink.
One picture printed fine, then suddenly the next seemed to put excessive ink on the photo paper, leaving a distorted picture. The ink is so heavy that it never dries and leaves spots of ink on my fingers when I pick it up hours later. The printing time shows 2:30 at first and then 1:00 before it starts printing.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Put in all new ink. Black ink blobs all over paper when I tried to print. Printing very light almost unreadable.
remove and reinstall the cartridge/s to ensure that they have been installed correctly before buying a new printer
May 07, 2016 | HP Photosmart C6180 All-In-One InkJet...
How do I print photos from my cd using hp Photosmart plus?
Don't Connect the printer. First use the cd to install the software for your printer. in the software is a program called print photos or print pictures. After installing the software, connect the printer and switch it on. Start the software and a menus should guide you trough he straps to choose and print the pictures you want to print. Be aware you need to setup things once the program is running, like how big the pictures should be. Don't make them bigger than the paper you insert. Also what kind of paper you use, like plane paper, or photo paper, matte or glossy.
Mar 20, 2015 | HP Photosmart Plus All In One Printer b210
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
My hp photosmart c6180 prints green photos on photo paper. it prints fine on regular paper. all my ink cartridges are hp and new. how can i fix this. i have tried several different types of photo paper as...
Check to make sure all of your contacts are clean. The part where the cartridge meets the printer. Also check to make sure you have it set in the printer properties for photo quality paper. If this still doesn't work, I would suggest trying a different brand of paper, it may be the problem with the paper manufacturer.
Oct 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Ink blobs on paper
It could be both. Leaky ink can be a problem and that probly is the problem. But, make sure your rollers are clean and cheak that your ink is not leaking. I hope this has helped you.
DigicalJAI
May 19, 2009 | HP Photosmart C4280 Aio Printer
My printer has suddenly started printing terrible quality photos
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
Photo printing
What program are you using to print out photos?
Try to take the ink cartridge out and put it back in.
Go to this link, instructions on how to replace ink cartridges
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
And then try to print. If you have the same problem, try to use another program that you can print pictures from.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
HP Photosmart D7260 Printer Logo
151 people viewed this question
Ben Johnson
