Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool Referigator Side x Side Not Cooling
Problem 08275MC
I am having a problem with a Whirlpool Referigator Side by Side M/N - ED25Q FXHW00 , S/N- SK0143090. The problem goes something like this. The refrigerator and freezer will work properly for several days in a row. Then it will be found not running and the ice in the freezer starting to melt. The problem can seemingly be corrected by turning the thermostat (cold control) to the off position. And then returning it to its normal setting. At this time the refrigerator will kick on and start running and will once again work properly until the next time it is found off and ice melting in the freezer. This same scenario has been going on for many weeks now and the problem does not seem to get any better or any worse. At first thought it would appear the that the cold control is defective, however, if that is the case. Why will it work for several days in a row as it should, and then shut off and not restart? Is this a constant cut in type thermostat and could this have anything to do with the problem? Can you propose a possible solution or solutions with an explanation as to what is occurring here.
  • 15,935 Answers
Http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf
This is a link to your manual.
Sounds as if the auto defrost circuit is malfunctioning.
Posted on Jan 06, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jan 06, 2009
    Additionally, if it is in a cold environment like a garage (since you state you dont check it daily - until the ice is melting) the auto defrost may be sensing the air is too cold, and going into defrost mode.
  • blueextc3221
    cold control thermostat is your most likely component to fail
    test it by tapping it instead of turning it off & back up next time. If the compressor kicks in when you tap it, you have found the culprit
  • blueextc3221
    http://www.partselect.com/AdvancedModelS...
    Here are blowup diagrams of your unit... and the proper #s you will need for replacement parts.
    Good Luck!
  • Whirlpool Master
  • 19,396 Answers
That is a defective thermostat, here is the replacement Cold Control Thermostat
How do I install insulation around my referigator door
You have a bunch of screws all around the gasket, pull the old gasket back to see them. Hard job even for a service tech, good luck!
Mar 15, 2013 | Hotpoint HSS25GFP Side by Side...
My may tag referigator not colling...frezer seems to be working fine
look in back of freezer for ice / if so you need my help not a un comon problem as the defrost system has failed . mm
Sep 02, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
No water hook-up
you can buy a little pressure pump similar to what r.v.'s use but 110 volt a.c. instead of 12 volt d.c. for about 80 bucks.
Jul 23, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Whirlpool side by side not cooling
check behin the fridge. try listen the compressor. not hear the com.? maybe time for a new fridge. unless is under full warranty
Mar 31, 2010 | Whirlpool ED5GTNXMQ Side by Side...
Whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Nov 12, 2009 | Whirlpool ED5FHEXMQ Side by Side...
No power
Fridge is 60% nit working.The freezer is -20%.Circuteboard was replaced and defrost controler.Referigator does not work.Service technition has tried three times to repair.Referigator is 14months old.
Aug 05, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
AMA BX21 7 years old Came home found freezer warm and thoughted, top referigator was still almost cold, have bben gone 5 days---the compressor keeps trying too start but cuts off after 30 seconds ,...
Look inside the fresh food compartment. Behind the temp. control cover is a defrost timer. Yours may have a small opening that you can put a pencil eraser in and turn clockwise. When you do that the refrigerator should begin cooling again. I will be here to help you get your refrigerator going with diagrams and part numbers, Thanks, Sea Breeze
Apr 20, 2009 | Amana ARB8057CSR Bottom Freezer...
Hi I on 1-6-09 submitted a request as follows: Problem 08275MC I am having a problem with a Whirlpool Referigator Side by Side M/N - ED25Q FXHW00 , S/N- SK0143090. The problem goes something like...
well   i cant refund you but i will do my best to help you.   it seems that you have two problems.   everybody knows metal shrinks when it gets cold.  i see that as part of your problem.   something in the control panel is getting cold and shrinking off of its mark.  most likely the thermostat.  which leads me to your second problem.  have the thermostat looked at.  if i was close   i would look at it personally.   i do apologize for the charges to your credit card.  i hope that your future Fixya.com experiences are much better
good luck
Jason
Jan 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
24 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
