Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
After cycle appears to finish an digital error code E1 pops up in display,then a continuous beep...
(More)
After cycle appears to finish an digital error code E1 pops up in display,then a continuous beep sounds. dishes are dirty yet and dont dry thats
hi, i have eurotech EDW194E dishwasher and after i start any program it starts filling water and...
(More)
hi, i have eurotech EDW194E dishwasher and after i start any program it starts filling water and then directly it is giving error E1. I did not find any help on internet could you support me Regards Mahmoud
The cycle finished, dishes clean, detergent used...but there is a big puddle of water at bottom of...
(More)
The cycle finished, dishes clean, detergent used...but there is a big puddle of water at bottom of dishwasher...help! I have a EDW194E model...thank you!
My husband recently installed our Eurotech EDW194E dishwasher, never used yet. There is a white...
(More)
My husband recently installed our Eurotech EDW194E dishwasher, never used yet. There is a white plastic piece, sort of shaped like an L if you stand it up. It is about 8 inches long and about 3 inches tall. The main part is about 1/2 wide, the little shelf thing on the botton (unless I have it upside down) is about an inch. It has a small piece that pulls out of the top, which has slots in it. What is it for? Should it be installed somewhere before we use it?
My 2 sets of large plate racks are rusting
and breaking. Do you know where I can...
(More)
and breaking. Do you know where I can order
replacements?
Thanks
