Question about Zanussi FJS1225W Front Load Washer
Clanging noise out of the machine when going through the spin cycle. The noise gets worse as the spin speed increases. Are there bearings that can be replaced ?
    Problem Solver:
  • 14 Answers
It could be a number of things. Anything from drum bearing failure to something as simple as a coin becoming trapped inside the tub under the drum.
More info here
Posted on Jan 06, 2009
  • Zanussi Master
  • 3,463 Answers
Yes it is the main bearings, and they can be replaced.
If it has no removable rear panel ,then it is a major repair job, as it entails removing the cabinet and stripping the whole washer down, removing the complete drum assy from the cabinet and seperating the 2 drum halves, a major undertaking.
How ever if it has a removable rear panel, then the repair can all be done from the rear.
Hope this helps with your prob.
Plz rate my comments to your prob.
Thanks
During spin cycle drum makes loud noise. Sounds like bearings are going out. Can they be lubricated? Or replaced
Depends on what sort of machine it is. (Front or top load)Bearings can be replaced but this will always entail replacement of all the tub seals and in the case of front loaders, almost always , it will need a new drum shaft. The costs to fix can be expensive. To confirm bearing failure, you can see if the tub moves and clunks on the main shaft and the noise will increase as the tub speed increases. Drum bearings usually fail when the tub seal fails or is worn out, allowing water to get into the bearing and wash all the grease out. Brown , black greasy stains under your machine and on the floor is usually a telltale sign as well.
Mar 20, 2017 | Washing Machines
My Samsung wash and dryer model WD0704REU makes a noise when spinning the clothes. normally it's quite but now make a sound. it gets louder with speed increases. please help,
I suspect that you either have a Tub bearing problem; there might be a fault with the inner tub (it has come loose on its mountings). or the counterbalance weights on the outer tub may have worked loose.
But from the limited information you have given, I tend to think that the inner tub bearings may be failing?
I hope this helps?
Sep 27, 2016 | Samsung Washing Machines
Vibration at highway speeds loud humming noise,
Possibly a wheel bearing issue, does it `get progressively worse as speed increases or better as it decreases? does it stop when applying the brakes or get worse?
Oct 30, 2011 | 2006 Ford Escape
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Noise when high speed spin cycle
maytag washer makes a noise when washing or spinning. sounds like a screw is stuck or maybe a bearing is going. It is getting worse each day.
Dec 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Clanging noise when drum going round loader on faster spin
it may be something between the drum`s or your bearing`s going
Nov 03, 2009 | Indesit W 123 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
180 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
