Question about Dell 926 All-In-One InkJet Printer
Dell Photo 926 AIO "Load Paper" error
Printing on lables: a lable peeled off and took what appears to be a sensor with it. Managed to open shell and put sensor back, but now printer doesn't recognize paper.
Nothing appears broken, the two tabs on the "sensor" are still in tact and snapped back in with little force.
Location of sensor: In the paper feed, in the middle. You can see it looking down.
Let me know if I can elaborate
Solved myself: I reseated the 4 internal wire harnesses and ribbon cables. None of these were obviously loose, but it seemed to do the trick.
Posted on Jan 07, 2009
I'm tryin g to scan a photo with my Dell AIO 926 Printer, connected to my Dell Inspiron 1525 laptop. But the laptop doesnt seem to be bringing up the AIO 926 printer file folder/menu, and when I request...
Did you figure this out? You should have a "Dell All-In-One Center" that was installed with the drivers for the printer. Try searching for it by pasting that phrase in the box in your "Start" button. When you locate it, drag the shortcut to your desktop or up in the top of the programs in the Start location. When you click on the Dell All-In-One Center icon, you should find some options for scanning.
Nov 12, 2010 | Dell Photo 926 All-in-One Printer
Deleted the whole Dell photo aio 926 program in error. Try to run the orig cd that came with printer but it won't run. How can I get it back? Went to search and came up with 'google icon' and 'folder' but...
Try reinstalling the printer using the instructions located at....
926 Photo All-In-One Printer owners thread (W7)
You'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer.
Install the proper drivers. You'll get the message, the printer is not connected. Connect the printer at this time.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
My printer appears to be printing the lables but
Make sure you are using thermal paper roll and not regular label roll.
Oct 05, 2009 | Zebra TLP 2824 Thermal Label Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the...
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
Dec 22, 2008 | Dell 926 All-In-One InkJet Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Dell 926 All-In-One InkJet Printer Logo
279 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
