Question about Esselte DYMO LabelWriter 320 Thermal Printer
Dymo 320 thermal label printer: The printer suddenly stopped printing ... the labels spool through and the printer makes it's normal noise as if printing ... but no printing is done ... possibly the thermal side of it has failed? I have reinstalled the software and checked all leads etc. Dec@makehits.com
  • makehits Jan 26, 2009
    Yooperbud
    Since my initial question, the answer was so stupidly obvious.
    The roll of labels were inserted upside down ... so the thermal printing did not work.
    However, since applying all the suggested remedies, the printer now DEFINITELY will not accept info. from the computer .... depsite three weeks of helpful but useless advice from a very helpful DYMO support desk.
    I have now downloaded and reinstalled so many drivers etc. it is crazy ... and still the computer will not communicate.
    Dec@makehits.com
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Crashes after pressing print
If a LetraTag produces blank labels or switches off, exchange the batteries. If the issue persists, please ring us. See dymo.com for numbers.
^CM
DYMOsupport
Mar 27, 2014 | Dymo LetraTAG Thermal Label Printer
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 450 prints too many lables
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option.
^CM
Nov 23, 2011 | Dymo ® LabelWriter® 450 Series PC...
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
My Dymo Labelwriter 400 turbo will not print. The print error comes up and does not tell me what is wrong. When I take the labels out and reinsert them the labelwriter will not load I have to unplug the...
In most cases, problems are solved by checking whether the spools are firmly pressed against the label roll: This machine can be very picky. Many questions can be answered at the following site. http://global.dymo.com/enNZ/HowTo/LabelWriter_400.html
Chris Thrash
B52Computers
Jan 19, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
My dymo label writer twin turbo stopped printing on left side!
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
Machine sends out blank labels when asked to print a label
I've had this problem several times and it seems that you need to push in the lock ring of the spool as far as you can tightly because if the end of each label is not seen by the sensors than it just keeps pushing the papaer out. Also make sure that there are no labels loose inside the machine that are covering the sensors.
Mar 18, 2009 | Dymo LabelWriter 400 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo 320 labelwriter downloadfor windows vista
Goto this page :
http://www.dymo-label-printers.co.uk/DYMO-LabelWriter-400.html
And click the 2nd icon along (XP/Vista Drivers), make sure to read the documentation before trying the driver as only some 300 series labelwriters are supported. If you specific model number (label on the underside of the printer) is not listed then it will not work under Vista.
May 14, 2008 | Dymo LabelPOINT 200 Thermal Printer
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Esselte DYMO LabelWriter 320 Thermal Printer Logo
345 people viewed this question
Top Esselte Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Esselte Office Equipment and Supply Expert? Answer questions, earn points and help others
