Problem sir i am having kingston32gb if inserted andclick on that drive it is showing that unreadable
  • Prashant Bharadwaj
    Prashant Bharadwaj May 11, 2010
    - is it a brand new product?
    - any data in it?
    - tried with any other computer?
  • 34 Answers
Hopefully I can try to walk you through a process that I would use.  First check to see if the flashdrive is damaged.  Usually the cases don't break, but the USB connector itself takes a lot of hits/damage/wear.  You should be able to see 4 metallic contacts on the USB connector and they should be in good shape.  Blow out any dirt/garbage in the connector as well.
Next is to see when you plug it in if the LED on it lights up at all.  If there is no light whatsoever, it is one of two things, either the flashdrive is totally broken or you have a failled USB port.  Either one is possible.  If possible, take the flashdrive and test it on another system, or at least another USB port.  That will give you some important information.
Assuming that the LED lights, then it is a question of getting Windows to recognize the drive.  If there is nothing important on the drive, fdisk the drive in DOS, then format it, and then Windows should recognize it, allowing it to be used.
If you have no LED lighting on the flashdrive, after testing on another system as well, get another flashdrive (or return this one if under warranty), since there are no real parts to service/fix.
Hope this helps out!
Posted on Jan 06, 2009
When insert the pendrive it shows that "need to format the disk" but it is not done
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here
Sep 25, 2013 | Electronics - Others
Disc is unreadable how do i fix it?
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the console not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Console including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Console going again!
Hope this will help...
May 27, 2010 | Microsoft Xbox Console
Windows XP Professional With Servise Pack 2 (e8503040) for PC: sir my pen drive is not showing in windows xp .\r\...
it may happen in some case when you are inserting your pendrive first time it will get installed its driver and all itself so it might happen that you have to restart. you can also update this USB driver..
May 18, 2010 | Microsoft Windows XP Professional With...
Bought a new Sandisk 8GB microSDHC card (Product Description : Micro SD/8GB SDSDQ-8192-P36M) for my Nokia E51. It worked fine for two months, in this had many times used in PC with my card reader for...
try formatting ur card with the following steps:
right click om my comp then click on manage then disk menagement and right click on ur card then format it will forcely format ur card. gud luck....
Oct 19, 2009 | SanDisk 8GB microSDHC Memory Card with...
Problem in external hard disk
Type this command in command prompt " chkdsk /r " in specfic disk prompt (eg) f:\> chkdsk /r
Oct 05, 2009 | Western Digital My Book Essential Edition...
Getting message "pls insert disk in drive" on inserting the USB
Hello sir/Madam,
You can recover by doing the following:
go to transcend website and download this software;
( and then you have to select repair and save data..
andthen also if you dont get ur full data,you can download Pen driverecovery from many sites(search on google) and recover or else email meat for full software..
Devesh Golani
Mar 10, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
Feb 16, 2009 | Toshiba Satellite U305-S2804 Laptop
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
Jul 27, 2008 | Computers & Internet
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
