Question about Whirlpool LSN1000LW Top Load Washer
Water leaking inside the washing machine
Small water leak into the washing machine.  Overnight I have at least 2 gal of water in the machine.  No leaks on the outside. Water just coming in the machine when it is not in use.
  • 115 Answers
You need to replace the water valve there should be 2 screws in the back bottom corner of your control panel take them out then stand in front grab each side of control and slide foward control and then pick up and lean it back then you will see a 2 clips holding you housing of your washing machine and a plug undo the clips and unplug the wire once done that grab each side of the casing and swivel it foward then slide the bottom front foward now you can access the water valve to replace it please rate
Posted on Jan 06, 2009
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
Leaking water onto floor from inside machine
2 common places.1 leak from the pipe/s from the valves to the dispenser box,2 @6 o/clock position in the fold of the door seal is where these models produce a small split.filter not tight.water bubbling over stand pipe when machine pumps out?these machines are usually fairly leak free so might be just one of these things i`ve listed here with luck.
Dec 29, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a GWL11 washer that has a small water leak that appears to be clean water. I looked underneath and couldn't see where it was coming from.
Sometimes water can leak from the hoses where they join the taps and/or the water inlet valves..Check for leaks by running you hands along the hoses and unions. Or there may be a problem inside the area behind the display panel...Unplug at wall and remove the 2 screws at rear of display panel. You may have to remove the lid by sliding it upwards while on the open (vertical) position..sometimes the mixer box leaks where the temperature sensor probe connects...Good luck...Nomess
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Leaks water inside washer overnight
Could be water fill valves ,,try turning them off for a few nights if this workds ..hey presto..if not could be drain too low,, water entering via sink outlet /drain....in this case raise hose..hope this helps you can let me know.....
Sep 29, 2009 | Washing Machines
Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Sep 14, 2008 | Washing Machines
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
462 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
